Results 1 to 15 of 31
Thread: Bit Storage
3rd Jul 2015, 08:35 AM #1
Bit Storage
YEsterday I added to my collection a few small Icecream tubs of drill bits, Milling Cutters and Taps. I think the old bloke must have been bringing one home a week from work all his career. He said he intended to buy a small mill and lathe for home in retirement but his wife had other plans.
I don't have a mill yet but hope to be able to do some in the lathe once I make a collet chuck. Is there a difference in using the two vs four flute mills for this?
Now the actual point of this thread I am interested in seeing (photos please) how you guys store these items so they are easy to find the size and don't get damaged?
- Mill Cutters
- Taps
- Reamers
- Drill Bits
- HSS Lathe Tools
I'm sure some of you guys will have some very innovative solutions that can inspire others or some very quick and easy ones.…..Live a Quiet Life & Work with your Hands
3rd Jul 2015, 08:44 AM #2Most Valued Member
- Charlestown NSW
- 1,673
Generally a two flute is called an "slot drill". If you look at the cutting end you will see that one flute is ground so that it extends past the centre. This enables you to drill a hole or plunge cut into the job then cut a slot by going sideways.
A four flute is usually whats called an "end mill". If you look at the cutting end of one of these you will see that the ends of the flutes are the same length and except for the very small ones there is usually a centre hole in the end. You can't drill a hole or plunge cut with one of these. Only from an existing hole or from an edge.
There are also variations on these. You can also get 3 flute slot drills.
bollie7
3rd Jul 2015, 05:39 PM #3Cba
- Aug 2007
- 68
- 1,410
The wooden blocks are made from hardwood cutoffs (left over when making new door jambs) - or whatever nice wood scrap is at hand. These are about 20mm thick planks. I glue tree of them together, then saw to a rectangular shape to suit. Drill holes for whatever tools needs to fit. Then spray with clear laquer like Estapol. Add four thin rubber feet for stability. Done. Its practical, space saving, and looks good.
I highly recommend FC cutters (also called throwaway cutters). These have 3 lips, one of which is center cutting. They are suitable both as endmills and as slot drills, so no need to buy both:
http://www.ebay.com.au/itm/Set-of-10-HSSCO8-FC3-milling-cutters-High-Quality-/281249756647?pt=LH_DefaultDomain_3&hash=item417bcab5e7
3rd Jul 2015, 07:18 PM #4
I got more 2 flute-Slot Drills than I did 4 Flute End mills. Can I assume that the 4 Flute therefore gives a better surface finish than the two, based on the description Bollie gave??
CBA, Is there any issue with wood reacting with the metal and rusting? I think it has something to do with Tannin levels? Or does the lacquer you use seal it in?
I did see someone say there were some good CD/DVD drawer liners from Ikea but I can't seem to find them on the website so they may have disappeared.…..Live a Quiet Life & Work with your Hands
3rd Jul 2015, 08:21 PM #5Member
- Nov 2011
- Sutherland Shire, Sydney
Rust on shanks?
Very impressive set-up you have there CBA. I am also concerned about rusting of the shanks in the wooden blocks. Will be most interested in how yours have survived with the Estapol coating.
Alan...
3rd Jul 2015, 09:30 PM #6Most Valued Member
3rd Jul 2015, 09:48 PM #7
ABSO-BLOODY-LUTELY with some species. Do not use She Oak or Silky oak. I made these a few years ago:
The Brad points are HSS M2, and the Forstners are HC Tool Steel. The She Oak rusted them so badly that a couple that I hadn't used for 12 months or so had to be held in a vise while I would the drill bit hold off it...... (not forgetting the HSS M2 doesn't rust anywhere nearly as bad as Tool Steel).
I changed them over to Huon Pine and oiled the insides of the holes - no problems.
Now here's the thing: the bits that rusted the worst were German made HSS M2 brads. The set of Suttons/Frost twist bits are also HSS (that you can see have the business end into the She Oak) didn't rust AT ALL, and still haven't. The point being that the Frosties are made in China....Regards, FenceFurniture
3rd Jul 2015, 10:03 PM #8Product designer retired
- Nov 2006
- Heidelberg, Victoria
- 79
- 2,074
Storage containers,
I'm in hospital three days a week, and keep my eyes open for things that may do for something else.
I reckon the blood sample tubes would be ideal. They are about 100mm long, 14mm in dia, transparent with a snap on lid.
I'll grab some next Monday and report back.
Each day, metres and metres of clear plastic tubing gets tossed. This tubing is used for blood transfusions etc, so a bit suspect to reuse.
Ken
3rd Jul 2015, 10:04 PM #9Most Valued Member
In a perfect world feed is worked out per tooth.... twice as many teeth means you can feed twice as fast.
Now that typo gave me a laugh
I've many milling cutters in a chipboard(yellow tongue flooring) holder and haven't noticed a rust issue. But it would seem location has something to do with it.
In my Hauser manual it makes mention of some tools been supplied in paraffined wood holders, which I thought sounded interesting, but google didn't come up with anything.
3rd Jul 2015, 10:15 PM #10Member: Blue and white apron brigade
If the wood has a lot of tannin in it then the steel should not oxidise/rust, instead it will form a black layer of Ferrous tannate which is inert and resits rust. It is usually quite a thin layer so unlike rust it won't affect accurate tool holding.
The problem with furry/unfinished wood is it absorbs water and that's what causes the rust. The wood can either be sealed with something like a poly or a squirt of machine oil which absorbs into the wood and then also protects any steel.
Folks with clean habits that completely clean their tools before they replace them may have more rust problems than those that place the tool back in the rack covered in lube etc.
3rd Jul 2015, 10:24 PM #11Cba
- Aug 2007
- 68
- 1,410
The more flutes, the more metal can the cutter remove per revolution, and the faster you can feed - on a rigid mill. The X3 is not that rigid.
I notice no difference in surface finish based on number of flutes. What definitely makes a difference is if the flutes are really sharp. Blunt cutters cause larger forces and hence more chatter and worse finish. I do not recommend coated cutters for a hobbymill, uncoated ones are sharper. Some coated cheap Chinese endmills I once bought to try, went into the rubbish bin after being used once or twice. HSS-Co is what lasts by far longest for me, and therefore is cheapest to me. Solid carbide I only use on hard materials where its the only choice - I have chipped or broken several small carbide cutters over the years on my small Toyo milling head, they are very fragile and do not like the vibrations of a small mill (the toyo is 20 times lighter than the X3, but still I am careful with carbide cutters, good ones are expensive and it hurts to loose one).
Some of the tools in these wooden block have been there for 25 years and still not the slightest trace of rust. After spraying the drilled blocks with varnish, the holes remain dry. The spray does not enter the holes. When storing a cutter (or whatewer it is) away, I liberally oil the shank with 3in1 oil. The wood abrorbs that oil and seems to protect tools very well. The holes are good fits to the tool shanks, so no humidity enters around the shank. The wood types I used lately are mostly plain Meranti, but some older blocks that I made probably 30 years ago were made from unknown wood salvaged from cigar boxes that the tobacconist gave away for free, top and bottom veneered with top qualit baltic beech plywood (yes I am also into moel airplanes) and the side veneerd in Mahogany veneer cutoffs. Too much work nowdays.... and no more cigar boxes around.
But yes, there may well be some wood types that could cause corrosion - I just was fortunate not to have had them in my wood scraps bin.
3rd Jul 2015, 10:50 PM #12
What about some 25mm thick delrin sheet for your drill bit, taps etc, tool blocks
It won't rust the tools an is impervious to oil.
It not too bad for price.
You may be able to score some as scrap at a plastic shop.
4th Jul 2015, 09:49 AM #13
although majority of my new ones are in original boxes and containers my old ones get tossed into a small tin and a yoghurt container many are difficult to read sizes so I purchased a drill gauge with intent of making a drill stand still not done yet.
Now as of yesterday I have a small collection of long reach drill bits to store so watching for ideas.
4th Jul 2015, 10:54 AM #14Most Valued Member
4th Jul 2015, 10:59 AM #15Most Valued Member
- 4,258
you guys are too organised
PM storage???
By JTTHECLOCKMAN in forum FORUMS INFO, HELP, DISCUSSION & FEEDBACKReplies: 4Last Post: 29th Jun 2014, 09:59 PM -
Tap and Die storage
By bts in forum METALWORK GENERALReplies: 16Last Post: 17th Jul 2012, 07:42 PM
