Results 1 to 15 of 61
28th Jun 2015, 01:19 AM #1
Needing Some For A Small Surface Grinder Job in Melbourne
I am in the process of restoring an old Waldown press here. I want to have the table and the flat surface on the foot surface ground and I am wondering if anyone would be interested in taking on the job.
I am happy to reimburse you for your time and effort.
28th Jun 2015, 08:10 AM #2Pink 10EE owner
- 6,216
You would need a massive surface grinder to do that job me thinks...
28th Jun 2015, 08:42 AM #3Most Valued Member
Hi mate,
I'm quite happy for you to come around and see what we can achieve using my sg. As RC says, thats a very big work envelope you would need. My sg can do 450mm x 200mm which would cover maybe half of that. I'm not sure, maybe you could do it in two passes.
See what others think but the offer is there. No cost involved. I'm near Hastings.
28th Jun 2015, 10:43 AM #4.
- 6,458
Thumb,
Using a shaper might be an alternate and maybe more appropriate means of refurbishing the base and table. My 10" Douglas was a touch too small to tackle the Waldown base but it did a great job in my opinion on the smaller Tough drill's base. http://www.woodworkforums.com/attach...1&d=1335577198
A number of forum members have shapers of a size that would make easy work of the table and base.
You can plug the holes in the table. I used cast iron - http://www.woodworkforums.com/showth...78#post1502378 Others have used epoxy mixed with cast iron dust to good effect also.
BT
28th Jun 2015, 10:46 AM #5
Hi Simon - thanks for the offer. When I said small I sort of meant not many pieces. I did not consider what effect the size of the pieces would have. I am in Coburg and Hastings is a long way for a man with no car (going for my licence in a month) and who depends on others to move big things around. However if no one closer can be found then we will have to find a way to take you up on your offer.
28th Jun 2015, 11:12 AM #6
Bob thanks for the link. I was leaning toward filling the holes with mild steel rod as it would be easy to get, however cast iron would be nicer. Does Interlloy sell small section of 4E? I might have to commission someone to turn down some plugs for me.
Is Loctite heat resistant? As I am getting the drill press power coated. I was thinking of welding the rod in place.
Bob first time I ever heard of a shaper, interesting tool.
Its like a cross between a surface grinder and a scrapping plane.
I was thinking of using a flap abrasive wheel to grind the deeper dings on the foot down. So that the final finishing would be a quick few passes. Good OR bad Ideas?
Bob I will look at my irregular hole in the middle of the table to see if it could be milled out nice and clean like you did.
I have used metal lathes and milling machines at University but I do not have access to such thing these days.
28th Jun 2015, 07:49 PM #7Most Valued Member
- 5,945
28th Jun 2015, 09:30 PM #8Senior Member
- May 2012
- Kimberley, West Australia
- 176
Waldown restore
Several quick questions. Does the table rotate around its centre? Is the column mount on the foot casting in the same plane as the main flat surface? If so, it should be possible for someone with a larger lathe to swing each piece in a 4 jaw chuck and take a facing cut on each, perhaps after the unwanted holes have been plugged. Regards,
Combustor.Old iron in the Outback, Kimberley WA.
28th Jun 2015, 10:16 PM #9Golden Member
- Mar 2009
- 54
- 825
G'day Thumb,
You are welcome to bring it around and I can have a crack at fly cutting it for you. I'm in Fawkner, I could even swing around and pick you up if necessary. Regarding the holes, some kneed-it epoxy metal will do the job, the fix won't be invisible but it'll be functional.
Greg.
29th Jun 2015, 05:26 AM #10
I have the following holes sizes - one @ 12mm, 6 @ 6mm, one at 28mm. I am happy to pay for time and postage if you are happy to part with some wrought iron.
All my reading says that powder coating is more durable and less prone to chipping then paint.
OK I wil not use the angle grinder.
Greg
That would be great especially the pick up, are you still happy with a case of beer?
Combustor
I will have to check.
29th Jun 2015, 09:32 AM #11Golden Member
- Mar 2009
- 54
- 825
G'day Thumb,
If you can get the CI from Kryn then I can machine the plugs as well. Not sure how hot things get when powder coating, it might be better to plug your holes and machine the table after you get it done. For what it's worth, I'd go with painting rather than powder coat, a decent enamel is plenty strong enough for machine tools. The other thing is unless the base has some really bad damage there's probably no need to machine it but I'm happy to do it if you want. A case of Little Creatures Pale Ale sounds fair.
Greg.
29th Jun 2015, 09:43 AM #12Most Valued Member
29th Jun 2015, 11:54 AM #13
Greg it is a deal.
I will try to get the RI.
Power Coating goes to 220º.
Most glues fail below that temperature.
So that is why I am leaning toward welding the RI in.
The damage to the base is minor, but I have come this far so I might as well go all out.
I will be in touch.
29th Jun 2015, 12:40 PM #14Golden Member
- Sep 2008
- Riddells Creek, Vic.
- 831
29th Jun 2015, 01:05 PM #15Golden Member
- Mar 2009
- 54
- 825
I'll be using a Thiel Duplex 158, swinging a UPA-4 boring head as a fly cutter.
Making a proper fly cutter is on my to do list but the boring head works fine with small cuts so it's a fair way down.
Greg.
surface grinder
By allterrain50 in forum METALWORK GENERALReplies: 4Last Post: 27th Apr 2014, 04:06 PM -
VICTORIA Surface grinder
By ersbruce in forum METALWORK - Machinery, Equipment, MARKETReplies: 0Last Post: 5th Jun 2012, 02:19 PM -
Building a small surface grinder
By jhovel in forum METALWORK GENERALReplies: 20Last Post: 14th Sep 2011, 11:30 PM -
surface grinder
By China in forum METALWORK GENERALReplies: 0Last Post: 19th Feb 2008, 12:48 AM
