Page 1 of 2 12 LastLast
Results 1 to 15 of 18
    Mar 2006
    13
    Default Grease Recommendation
    Can anyone recommend a suitable grease that can be used in woodworking machines? I need to re grease a spindle and quill assembly for a drill press.
    Nov 2008
    Perth WA
    6,459
    Thumb,
    You are probably not interested in my advice but you may be in Brobo Waldown's. Go the section 5 of this PDF. Different model drill but their advice would be the same for your drill.
    http://www.google.com.au/url?sa=t&rc...96339352,d.dGc
    Mar 2006
    13
    Thanks Bob. They recommend NLGI 2 extreme pressure grease OR Shell AlvaniaNo.1 grease.Now were do you such things?
    May 2012
    Kimberley, West Australia
    176
    Default Grease type.
    NLGI 2 is a class of grease available readily from must lube manufacturers. Shell just happen to call theirs Alvania 1 or 2.
    Combustor.
    Old iron in the Outback, Kimberley WA.
    Dec 2005
    Canberra
    490
    Head to your local auto shop, look at the wheel bearing greases and find one that mentions NLGI 2 (Penrite high temp wheel bearing grease is one that does).
    Or go through your garage shelf and find a grease that's a purple colour - that's a good indication!
    Oct 2008
    N.W.Tasmania
    1,407
    Quote Originally Posted by Master Splinter View Post
    I,m no expert on this topic, but Alvania, if it is an NLG1 type of grease was a yelowy brown colour if I remember, are most NLG1 greases purple, and for that matter is there a widely used colour code for grease types. I look forward to my education in matters Grease
    Rob
    Jun 2012
    SA
    1,649
    Quote Originally Posted by Ropetangler View Post
    Rob
    Good question. I doubt there's any standard on this - probably just the manufacturers constituents that determine it.
    I've used water proof grease that's been green, grey, and white.
    Same with rubber grease, black, blue, and green all been used.
    Rob
    The worst that can happen is you will fail.
    But at least you tried.
    Nov 2008
    Perth WA
    6,459
    Thumb,
    How about this, delivered to your front door - http://www.ebay.com.au/itm/PENRITE-M...item232c5744cb
    Aug 2011
    4,779
    Shell Alvania and now called Gadus. It's not all that easy to find but I bought some from ebay.
    Mar 2006
    13
    Question: will I need grease gun, or will it suffice to smear grease on all the components and assemble.
    There is a store near me that sells http://www.actrol.com.au/Products/Se.../Shell-Grease/
    Dec 2005
    Canberra
    490
    An old automotive teacher gave some general guidelines for grease colour - opaque white greases are for chassis applications, tan greases are general purpose, and translucent bluey-purples are bearing greases. Black greases are 'well past time to replace this grease' greases.
    He was from the days when you'd replace the Lucas fuel injection on your brand new English car with a couple of SU carbies to vastly improve the reliability.
    The NLGI number only relates to the actual thickness/viscosity of the grease, not to any of its other features
    Aug 2011
    4,779
    Quote Originally Posted by thumbsucker View Post
    I wonder how old that grease is? Not that it will matter for this application.
    Jan 2011
    Far West Wimmera
    63
    4,049
    Food grade grease used at work is opaque white.
    7,189
    Must have been in the days before MoS grease?
  15. #15
    Oct 2008
    N.W.Tasmania
    1,407
    Except I presume, the cases of Moly-disulphide and Graphite greases which are often black when new.
    That's interesting, I always presumed that the EP1 or EP2 designated the viscosity, I don't think that I was aware of the NLG1 number back in the day. My next question is therefore what does the EP 1 or 2 signify, differing levels of ability to handle extreme pressure perhaps. Perhaps thicker greases are not necessarily better than thin greases in their ability to handle extreme pressure, although one would normally intuit (is that a word) that the thicker the grease the more it would be able to handle higher pressures.
    Rob
    EDIT. PS Too slow yet again, you beat me to it BobL
    Last edited by Ropetangler; 24th Jun 2015 at 09:31 PM. Reason: BobL was too quick in his post above
  1. Which Grease Gun??
    By ventureoverland in forum METALWORK GENERAL
    Last Post: 9th Feb 2015, 08:21 PM
