Results 16 to 30 of 33
Thread: Disc and belt sander
20th Jun 2015, 08:12 PM #16New Member
- Jan 2015
- Gloucester UK
- 3
I use Zirconia belts for metalworking. They are very effective and last reasonably well.
Here is a UK source but no doubt they are available worldwide.
http://www.abtec4abrasives.com/100mm...belt-532-p.asp
Roger
20th Jun 2015, 08:33 PM #17
Sorry about that bit of misinformation! I shall give myself an uppercut!
I shall count myself lucky that I have an older Multi tool, then.
The new MT drive wheels must be from the same mob that made my 6x 4 bandsaw wheels as I got them with a wobbly boot in them (thanks H &F).
Yes a new attachment for the old girl would be a real good thing.
It is a really sad thing to see many of the good tools and machines we knew and trusted, now being corrupted under the same brand we knew and once trusted.
20th Jun 2015, 08:40 PM #18Golden Member
- Jun 2004
- Kyabram. Vic
- 632
Grahame,
Don't beat yourself up too badly; a light tap or 2 should be enough. When I bought mine I went by their good reputation. Sucked right in.
There is a thread on the forum about the problems with the rubbish. One member was on his 3rd (I think) drive wheel under warranty; and it was no better. I think that he gave up in the end.
Ken
20th Jun 2015, 09:13 PM #19Senior Member
- Mar 2014
- 46
- 121
The MT machines look the goods however for the price + the grinder it seems that a lot can be had with other dedicated machines(more heavy duty as well) and I do like the idea of a larger Disc sander. This is just from what I have seen is available on the H&F website. Certainly the zirconia belts look the goods for metals.
20th Jun 2015, 09:42 PM #20
Norton Blaze are the best belts money can buy for steel, the green ceramic belts come 2nd. The knifemakers consider zirconia to be good for handle shaping and not much more.....
Unfortunately i have only seen the blaze in 2" wide belts, Gameco stock them in 48" and 72", i think gasweld or total tools has them too.1915 17"x50" LeBlond heavy duty Lathe, 24" Queen city shaper, 1970's G Vernier FV.3.TO Universal Mill, 1958 Blohm HFS 6 surface grinder, 1942 Rivett 715 Lathe, 14"x40" Antrac Lathe, Startrite H225 Bandsaw, 1949 Hercus Camelback Drill press, 1947 Holbrook C10 Lathe.
20th Jun 2015, 10:05 PM #21Member: Blue and white apron brigade
- 7,182
I have two disc setups, the 6" on multitool than I never use and the other with the 12" disc on the 150 x 1000 mm variable speed Linisher that I have used maybe half a dozen times in the last year.
There's several things I don't like about discs,
The first is the variable speed from inner to outer parts of the wheel producing different sanding rates.
Then it's trickier to touch up small stuff, with a grinding wheel or a the wheel on a belt sander you can get in close and still see what is going on.
Neither belts or disc will hollow grind on their flat surfaces and if anything produce a rolled edge if any sort of pressure is applied.
23rd Jun 2015, 11:39 PM #22Senior Member
- Mar 2014
- 46
- 121
I have bitten the bullet and purchased the 12 inch woodfast disc sander. It fits nicely on my little bench between the small bench grinder and bench drill. newbie question but what's involved in changing the disc paper?
23rd Jun 2015, 11:45 PM #23Member: Blue and white apron brigade
- 7,182
The standard way is ti contact cement the disc on so a bit of heat from a hot air gun will soften that.
You might want to consider going the hook & loop route that way you can more easily change the paper. I have this on the big disc 0 haven't used it much but it sure is handy when you need it.
23rd Jun 2015, 11:50 PM #24Senior Member
- Mar 2014
- 46
- 121
Thanks Bob! appreciate it. That makes sense, i figured it must be some kind of glue. The hook and loop method seems the go. Is it worth gluing some thin rubber on the platen for use when sanding metal to help avoid tearing the paper which I assume its for as educated by previous post the differences between metal and wood sanders?
24th Jun 2015, 12:05 AM #25Member: Blue and white apron brigade
- 7,182
24th Jun 2015, 07:21 AM #26New Member
- Jan 2015
- Gloucester UK
- 3
24th Jun 2015, 11:48 PM #27Most Valued Member
- 5,942
Hi Maxi, I have the Woodfast as well fitted with the hook and loop. Unplug the unit from the power first.
The old paper is taken off by removing the table, then the paper and replacing it with the hook. Assemble with the loop paper and then refit the table.
I bought mine from the Sandpaper Man, listed on the side here.
When you go to replace the disc, I used an opaque flexible cutting board, rounded at the bottom, same diameter as the disc, then slide the flexible board between the disc and the loop, rotating the disc by hand as you go, it comes away after about 1 revolution. Putting the loop back on is the reverse procedure, lining up the loop with the disc, hence the opaque cutting board, and rotating the disc, pulling out the cutting board as you go.
Hope this helps.
25th Jun 2015, 01:16 AM #281915 17"x50" LeBlond heavy duty Lathe, 24" Queen city shaper, 1970's G Vernier FV.3.TO Universal Mill, 1958 Blohm HFS 6 surface grinder, 1942 Rivett 715 Lathe, 14"x40" Antrac Lathe, Startrite H225 Bandsaw, 1949 Hercus Camelback Drill press, 1947 Holbrook C10 Lathe.
25th Jun 2015, 12:57 PM #29Senior Member
- Mar 2014
- 46
- 121
25th Jun 2015, 04:12 PM #30Most Valued Member
- 5,942
Yes. that is how I remove and replace the loop disc.
I don't use the T slot, as if it's set for a ?degree, unless the table is perfectly parallel to the disc and the disc is dead flat it will be out. My disc had about 3 mm wobble in it, got a friend to machine it, ruined 2 carbide tips.
