Results 1 to 13 of 13
    Apr 2008
    Canberra
    805
    Default How to get fish oil off lathe ways
    Hey Guys,
    I have had thelathe in storage for the last 9 monthswhilst our house has been extended.Imfinally at the pointy end now, and have the lathe in my new garage ready forinstall into its final location.Howeverbefore I stored it I sprayed all of the metal surfaces liberally with fish oil(the stuff in the pressure pack can).Iam now having no luck getting it off.Itried warm soapy water, degreaser and turps but nothing would budge it.The turps worked the best, it seemed to getrid of a few small areas.
    Any suggestions?
    Jan 2004
    Mackay North Qld
    6,446
    Paint thinners or acetone should do it.
    Jun 2012
    SA
    1,649
    Try Acetone on a rag.
    Shifts most oil based residue.
    Have good ventilation or wear respirator with correct cartridge, and wear Nitrite disposable gloves (Blackwoods have them).
    Don't get it on the painted areas.
    The worst that can happen is you will fail.
    But at least you tried.
    Apr 2008
    Canberra
    805
    Cheers fellas. Ill grab some after work today and see how I go.
    Sep 2006
    South Coast of New South Wales Australia
    296
    Supercheap or Repco aerosol degreaser wouls be cheap and make the job easy.
    Cheers Jim
    My Youtube Channel -
    Blue Heeler's Model & Toy Steam Engine Room
    Jun 2007
    sydney ( st marys )
    64
    4,890
    Let use take it off.
    7,189
    For a couple of years I used canola as a cheap form of bar and chain oil on the Auxiliary oiler on one of my big chainsaw mills. Being less tack that regular bar and chain oil it made an unholy mess. Then one summer when I wasn't using the mill and had left the gear in a dirty state the canola oil covering everything polymerised together with the sawdust forming a semi-tacky layer everything . I brought it home to clean it up and left it on the back lawn and a few hours later I came out and found one of the dogs had started to do a pretty good job licking it off so I left her to it. She gave up after a couple of days and although she didn't do it all but I was amazed that she got most of the suff off the chain! I have photos of her doing it but unfortunately can find them.
    [EDIT] found one
    Jul 2006
    Athelstone, SA 5076
    4,258
    more fish oil?...to soften existing so as to allow easier removal with kero/petrol etc
    May 2019
    Tucson, Arizona, USA
    46
    Quote Originally Posted by 19brendan81 View Post
    Hey Guys,
    Any suggestions?
    Hi Brendan,
    I use lacquer thinner to remove fish oil from steel tubing I buy from the local supplier. I'm sure some other solvents would work as well. I like the lacquer thinner because it evaporates quickly and doesn't leave a residue.
    David
    Mar 2011
    Taree NSW
    119
    Quote Originally Posted by adbuch View Post
    Hi Brendan,
    David
    Hi Brendan,
    Have had the same problem as I use Lanotec on my equipment between uses but yesterday I used Brakeclean and it cleaned it up perfectly - I buy Brakeclean from Repco who occasionally have specials on it with 4 cans for $10
    Nov 2004
    Bungama SA
    52
    960
    try some WD40, if its cold some heat will help soften it
    Oct 2015
    melbourne
    473
    If it's not clean now it never will be.
    Original post was 2015...
    Russ
    Apr 2008
    Canberra
    805
    I did indeed get it off and for memory thinners did the trick!
  1. Roller grinder ways/ plain grinder ways
    Last Post: 6th May 2012, 12:37 AM
  2. Regrind of lathe ways
    By flmath in forum METALWORK GENERAL
    Last Post: 27th Jun 2008, 10:35 AM
  3. Hercus lathe, clean bed ways?
    Last Post: 30th Dec 2007, 12:53 AM
