Results 1 to 15 of 22
Thread: The Harrison has landed.
9th Jun 2015, 08:55 AM #1
Groovers, last month I acquired an old 3 phase welder from a family friend and while moving it I noticed this older Harrison l5 metal lathe there as well. Time past and I contacted him about the lathe, we agreed on a price and home she came via a tandem trailer and some head scratching and now she sits very firmly on the floor of my shed. The lathe came with both steadies, a Belco 4 jaw 8 inch independent chuck and a Rohm 3 jaw 6 inch.
As you can see the lathe was quite dirty as the protective oil coating had joined with dust to form a layer of scum. I am fairly sure that the 4 jaw has never been on the lathe.
You can see from the pictures that the cabinet door is off as the previous owner lost the key and ground off the hinges. I can live with that for the price I paid.
I removed the top cover to have a squizz at the gears and it looks rather good to me.
Almost forgot to say the price..........$300I'm a dancing fool! The beat goes on and I'm so wrong!!!!
9th Jun 2015, 09:13 AM #2Senior Member
- Aug 2012
- Adelaide Hills, SA
- 141
Well done
Looks great. Did you get the ground off door with it? There is hours of entertainment there for you, well worth every cent!! It should be very useful for many projects. Are you planning a full restoration or just to have it working well?
9th Jun 2015, 09:19 AM #3
Burner, the door was supplied and I spent a large portion of yesterday scraping and scrubbing gunk off of most seen parts. I removed the tail stock and cleaned it well, checked the oil level in the box, removed the grease nipples and subsequent rock hard grease, replaced with new grease, wired on a new plug, bit more scrubbing and a bit more scrubbing just for fun. I will post some updated pictures soon.
9th Jun 2015, 04:18 PM #4Most Valued Member
That's not a purchase, it's a steal. If you weren't so far away, I'd offer you $400 for it. Better still clean it up with a WIP, and I'll drool about it.
9th Jun 2015, 08:50 PM #5Golden Member
- Mar 2009
- 54
- 825
Nice lookin unit woody, lots of potential there.
You mentioned cleaning out the old grease and replacing it with new grease, I hate to be the bearer of bad news but you might have to clean out all your new grease and use oil instead.
In general where you have a grease nipple on a machine tool it's more than likely meant for oil. Get yourself some ISO 68 or 46 hydraulic oil, a Pom Pom gun and lube to your hearts content. You might also want to get an industrial size supply of rags to soak up the oil that leaks from the Pom Pom gun.
Greg.
9th Jun 2015, 08:59 PM #6
watching
regards
Nick
veni, vidi, tornavi
Without wood it's just ...
9th Jun 2015, 09:22 PM #7
Spent some time today cleaning the 2 vices with brass brushes, tooth brushes and scotchbrite pads. The 3 jaw chuck is stuck on the lathe and had to be separated from its backing plate. Pictures to follow as soon as the camera is charged.
As I said before the 4 jaw is an 8inch Belco made in England and the 3 jaw is a 61/2 inch Rohm.
Any ideas on how to remove the stuck backing plate from the 3 jaw?
Damien.I'm a dancing fool! The beat goes on and I'm so wrong!!!!
9th Jun 2015, 10:23 PM #8I'm a dancing fool! The beat goes on and I'm so wrong!!!!
11th Jun 2015, 10:55 AM #9Golden Member
- Mar 2009
- 54
- 825
G'day Damien,
A pom pom gun or push oiler looks like one of these:
http://www.ffx.co.uk/tools/product/L...%20Gun%20120cc
The one in this link is listed as a grease gun but the oil versions look the same.
You can probably pick an old one up at your local flea market or swap meet or buy a new one from Pirtek or similar.
Most of them will do the job as far a getting oil where it's needed on your machine but in general they leak like sieves when not in use hence my reference to a good supply of rags.
I finally bit the bullet and bought an Abnox Wanner version from a place in the US which from memory cost me around $130 delivered. This sounds a bit pricey I know but it hasn't leaked a drop since I've had it and given a crap one from Pirtek cost around $60 and was in the bin within a year I reckon it was worth the extra coin. I also modified a cheap little grease gun to pump oil which worked ok but I couldn't access some of the oilers on my mill but you may not have this problem so might be worth a try.
To remove the grease, flushing with oil will do the job in some places but you will probably have to do some disassembly for other places and wipe or scrape the grease out. This is tedious work but always remember, there's not many things more pleasant than some nice oily nipples.
Greg.
18th Jun 2015, 07:56 AM #10
A little bit more time spent with a toothbrush and diesel to clean both the chucks and the steadies. Both the steadies are missing at least 1 on the contact rods, these are made of brass so it should be easy to fabricate. Have a look. Damien.
I also spent some time scrubbing and oiling the Harrison. As you can see I still havent been able to remove the backing plate for the 3 jaw. Any advice will be welcome.I'm a dancing fool! The beat goes on and I'm so wrong!!!!
18th Jun 2015, 12:06 PM #11Most Valued Member
18th Jun 2015, 12:07 PM #12Most Valued Member
Is it possible to lock the lathe, so it won't rotate and slip a couple of bolts in the face plate, and put a lever on the bolts to undo it.
18th Jun 2015, 12:42 PM #13Most Valued Member
Just start off gently.
If it comes down to it, it will likely be less hassle to turn the backing plate off and replace it rather than having to replace some other part of the headstock.
18th Jun 2015, 02:18 PM #14Pink 10EE owner
- 6,218
To remove the back plate assuming it is a screwed thread chuck.., install the 3 jaw back on... Put about a 600mm piece hardwood in the jaws, at right angles to the bed...
Put the lathe in neutral, hit the wood with a sledge hammerGold, the colour of choice for the discerning person.
19th Jun 2015, 08:09 AM #15
Harrison L5 lathe?
By goodwoody in forum METALWORK GENERALReplies: 3Last Post: 28th Apr 2015, 11:40 PM -
Harrison L5 lathe
By morrisman in forum METALWORK GENERALReplies: 7Last Post: 4th Mar 2015, 07:05 AM -
Harrison L5A
By morrisman in forum EBAY, GUMTREE, and other off forum sales sitesReplies: 0Last Post: 5th Sep 2014, 11:03 PM -
harrison lathe
By morrisman in forum METALWORK GENERALReplies: 32Last Post: 18th Dec 2012, 09:50 AM
