Results 1 to 15 of 15
    Jan 2006
    Malvern East
    36
    Default Mounting my dawn 125 drill press vice
    Hi,
    I got my hands on a dawn 125 drill press vice to use with my drill press.
    It is in great condition.
    What I am not sure about is how to mount it to my drill table.
    Here is a picture of the two.
    What do you think?
    May 2011
    Murray Bridge S Aust.
    72
    6,242
    Hi Brenton,
    The way I'd go about it, is to find/get a bit of plate, 10 - 12 mm thick, the size of the table or a bit more, plus enough to put the centre of the drill bit with the fixed edge of the vise. Mark the centre holes of the slot, so that they intermix with the next hole, if the slot is 50 mm overall and it is 12 mm wide, the holes would be 38 mm centres, as one hole starts the next hole will take the bolt, theoretically you should be able to get 2 bolts in each slot. Thread them to suit the bolts to fit the slot. Mount the plate using the T slots in the table.
    Oct 2008
    blackburn vic
    297
    Default Vise mounting
    Hi Brenton
    I would either buy or make a couple of T nuts and make a couple of clamps. Then you can mount it anywhere on the table.
    Roger
    Jan 2006
    Malvern East
    36
    Roger,
    Do you have an example of what you mean?
    Brenton
    7,274
    I think he means something like this.
    The clamps can of course be as fancy as you like.
    Cam locking T-bolts would be nice.
    Nov 2008
    Perth WA
    72
    6,460
    Default Different Vice, Same Idea
    Aug 2011
    4,779
    And there we have it. Another famous Donna Hay illustration!
    Was that done in a studio Bob? I got the exact same vice but it does not look that good. Now I feel like crap and feel obligated to take it apart and lick it up on the sg! Nice jaws too. I got jaw envy too! Dam you.
    Nov 2008
    Perth WA
    72
    6,460
    Ha Ha! It only looks like that because the vice, clamps and table were all purchased new. Donna would be appalled if she saw the rest of the "studio" !
    BT
    Aug 2011
    4,779
    BT
    Of course you know me well enought to know I'm not suggesting you don't do anything in your shed. You churn out bigger and better projects at a rate I could only dream of!
    Nov 2008
    Perth WA
    72
    6,460
    Hardly churn Simon and definitely neither bigger nor better. And I do know you well enough.
    BT
    Adelaide
    69
    1,393
    May 2012
    Kimberley, West Australia
    176
    Default Dawn Vise Mount.
    Hi Brenton,
    Can't tell from the pic, but does your square table rotate on an arm, or is it fixed? If rotating, you can just drill the vise flange to align with your centre slot and use tee bolts and nuts shortened a little so that a workpiece will not catch them. I have my Dawn vise mounted thus on a circular table and can position any job under the drill by rotating the table and slewing the arm on the column. It's a neat simple 2 bolt mount and quick to remove for large jobs or machine cleanup. Regards,
    Combustor.
    Old iron in the Outback, Kimberley WA.
    6,881
    All those lovely pictures of nice shiny tables with T slots and pretty hold down clamps. I'm starting to feel left out...
    My FORBCO Star only has a pair of through slots and a hole in the middle
    Jan 2014
    Northern Beaches, NSW
    288
    BT
    Can I ask where one could buy a new Waldown vice & clamps from?
    I thought they were long since out of production.
    Thx
    Jon
    Thx
    Jon
  15. #15
    Jan 2006
    Malvern East
    36
    Quote Originally Posted by Combustor View Post
    Hi Brenton,
    Combustor.
    Hi,
    Yes it is a square table that can swivel.
    I think the t-bolt option is the way to go and I can the use the table to position the work under the chuck as required.
  1. Dawn 75 Drill Press Vice - Help Needed
    By Burnsy in forum METALWORK GENERAL
    Last Post: 21st Aug 2014, 08:49 PM
