Results 1 to 15 of 29
21st Mar 2015, 09:45 PM #1Member
- May 2012
- melbourne
- 60
Lathe spindle fwd-rev lever - is up usually forward or reverse ?
Is there a standard (for Australia) which says which way the spindle control lever should operate?
Is it up for forward, so the chuck direction is opposite to the direction of the lever? That sounds a little "American", like their light switches, but seems to have the advantage that it's a just quick swipe down to knock the lathe back to neutral.
Or is it down for forward, so the chuck rotation follows follows the direction of movement of the control lever. So down for "on" like ANZ, UK, Euro light switches, if you think of forward as "on".
After poking around the various manuals online it seems there's no "right" way, but I'd expect that somewhere buried in the standards, there is a "right" way, so that any machine you walked up to would operate the same way.
21st Mar 2015, 10:23 PM #2Pink 10EE owner
- 6,218
My Chin Hung, down is forward, up is reverse..
21st Mar 2015, 10:28 PM #3Mechanical Butcher
- Oct 2004
- Southern Highlands NSW
- 1,898
Depends on how many gears are in the train between stud gear and screw gear, which can vary.
Jordan
21st Mar 2015, 10:29 PM #4
Hi John,
I personally agree with your second comment, " down for forward, so the chuck rotation follows follows the direction of movement of the control lever".
Also if the control lever is vertical, then moving it to the right would run the chuck in the normal direction.
Though I can see the advantage of the American way, particularly for switches and the electrocution risks that they seem to have on that side of the pond.Best Regards:
21st Mar 2015, 11:46 PM #5Most Valued Member
- 4,890
22nd Mar 2015, 12:01 AM #6Senior Member
- May 2012
- Kimberley, West Australia
- 176
Control direction.
Am not aware of a "standard" for shop machines but several lathes and mills I use seem to have the controls set so that rotation and feed direction follow the movement of the control lever. Earthmoving gear seems to follow the same rule, and it certainly makes operator training a whole lot easier. Don't see the need to make any machine more complex than it has to be.
Combustor.Old iron in the Outback, Kimberley WA.
22nd Mar 2015, 12:17 AM #7Diamond Member
- Mar 2014
- South of Adelaide
- 1,227
On the 3 lathes at work with lever controls at work up is forward down is reverse. But on my VDF lathe at home down is forward and up is reverse.
22nd Mar 2015, 02:19 AM #81915 17"x50" LeBlond heavy duty Lathe, 24" Queen city shaper, 1970's G Vernier FV.3.TO Universal Mill, 1958 Blohm HFS 6 surface grinder, 1942 Rivett 715 Lathe, 14"x40" Antrac Lathe, Startrite H225 Bandsaw, 1949 Hercus Camelback Drill press, 1947 Holbrook C10 Lathe.
22nd Mar 2015, 06:51 AM #9Philomath in training
Standards are usually only set up to regulate the quality of items or safeguard the public. Where would you stop with machine tools and their controls?
My lathe is set up with up=forward. The machine is a little lower than ideal and it's easier to pull the lever up rather than push it away. At work it is set up the other way. It should not matter provided it does not cause confusion for operators (that is, they don't select reverse when they want forward). Turning on a lathe should be a conscious effort too, so thinking which way to move a lever is not necessarily bad.
22nd Mar 2015, 08:11 AM #10
This came up on US forum several years ago and it was about 50/50 which way was foward from memory, with no standard.
Mine is up for foward.Using Tapatalk
22nd Mar 2015, 08:41 AM #11Pink 10EE owner
- 6,218
It is sideways on the 10EE...
22nd Mar 2015, 10:00 AM #12Cba
- Aug 2007
- 68
- 1,410
Yes, I remember in Switzerland, many lathes had a knee yoke. Sliding the yoke left was reverse, middle off, right forward. Very handy. Or was it the other way around? Too long ago to remember. But it was always clearly labelled with arrows and large writings.
No, there definitely never was a standard. There are too many different switch layouts, too many locations where the switch may be placed. On a vertical shaft switch, the lever/handle may point forwards or backwards.... On a horizontal shaft switch, the lever may point up or down. Then some lathes have pushbuttons. Impossible to design a standard.
Also consider a 3-pase lathe. When the electrician hooks up the power, there is a 50/50 chance that he crosses two phases and the lathe runs in reverse with the switch on forward. And if the writing on the switch for what is supposed to be fwd or rev came off or became illegible, who would ever bother. Nowdays a larger/better lathe may well be fitted with a phase relay, that prevents it from being used if the electrician did hook up two phases crossed (but with modern lathes fitted with VFD, this would only matter for pumps and the like and not affect spindle rotation direction).
22nd Mar 2015, 10:18 AM #13Member
- May 2012
- melbourne
- 60
Maybe, Down=Fwd is more logical and perhaps a liitle more "British / Commonwealth" ?
Anyone remember which way the Colchesters in the TAFE's were wired ?
If so I'll make that my standard
I think it's sensible to have all machines in a workshop the same
I occasionally run my drill press backwards, the Clipsal rotary switch is FWD-O-REV, so anticlockwise for forward, seems illogical to me, but that's the way Clipsal made it, although maybe there's also a REV-O-FWD switch in their catalogue.
My little Schaublin lathe has a rotary switch with clockwise = Forward, seems perfectly logical, runs the right way without any thought required...... but then who says that's the way the factory intended it
22nd Mar 2015, 11:21 AM #14Tools are good, more tools are better!
22nd Mar 2015, 11:49 AM #15
Mine is up for forward, I prefer clockwise for forward in general, somehow it feels more natural?
On a related matter, does anyone know if there has ever been a lathe with the spindle on the right, and tailstock on the left... as seen by the operator that is... ( not standing behind the lathe! ) if not why not.
Turning lathe motor from forward to reverse
By Jim Ferrous in forum METALWORK GENERALReplies: 13Last Post: 19th Sep 2013, 03:34 PM -
SOLD: 415v motor with forward reverse
By Ch4iS in forum METALWORK - Machinery, Equipment, MARKETReplies: 2Last Post: 19th Apr 2012, 09:42 AM -
Mini Mill/Drill with forward/reverse
By Big Shed in forum METALWORK GENERALReplies: 3Last Post: 27th Feb 2009, 11:31 PM
