Results 31 to 32 of 32
Thread: Interesting 3P motor
10th Mar 2015, 10:46 PM #31Member: Blue and white apron brigade
A couple of things I forgot to mention about the fan on this motor
1) When naked it sure pumps a lot of air but the restrictive grille on the front of the fan cover knocks the stuff ing out of the air flow. I will rebuild the grill using some mesh
2) The fan is very quite even at 70Hz , pity the motor still squeals a little even with the more efficient of the two VFD
12th Mar 2015, 08:30 PM #32Member: Blue and white apron brigade
OK I reset the VFD to the factory settings and the current drawn by the motor dropped by about 30% but it's still almost double what the other 4kW VFD delivers to the same motor.
Now I'm frustratedly stuck in the rut where the VFD Pot only allows the RPM get reach half the max RPM AHRGGGH!
Looking to swap a 2Hp single phase motor for 1.5 or 2Hp 3-phase motor
By jhovel in forum METALWORK GENERALReplies: 7Last Post: 10th Mar 2014, 07:26 PM
