Page 1 of 2 12 LastLast
Results 1 to 15 of 25
Thread: Mounting Plate.
    6,477
    Lightbulb Mounting Plate.
    First, thanks for the birthday wishes, the banner was a complete surprise
    I've known that the head on my mill nods, for quite some time, and rather than strip the head and column off the machine, in order to fit shims under the bolts, I've decided to make a mounting plate on which to mount my new precision 90 mm milling vice.
    My theory is that by making a plate that fastens securely to the mill table, and then by fly cutting the surface of the plate, that it will be truly parallel to the head. I'm aware that it may only be correct for a limited amount of head movement, but it has to be better than the three thou across the width of the table.
    I've done a full size drawing of the plate and the four clamps for securing the vice to the plate. The steel plate is 12 mm thick and 160 mm X 220 mm, with drilled and tapped holes for M6 cap screws. I propose to simply glue the drawing to the plate and use it for marking out. I will place a piece of bar underneath the plate to accurately locate it on the mill table, so that when I come to take it off I can replace it and the vice will remain square to the table.
    If anyone can see a flaw in this scheme, please shout out. Thanks:
    Mounting_Plate.pdf
    Jul 2010
    9,088
    Happy Birthday.
    I'm not so sure that's going to change much, unless all you're going to be doing is making large parallel blocks. In fact at first thought for most things you're making things worse... but then I guess its easy enough to take it off if it doesn't work. The mill head will now be trammed to the vice... but it will still be out in relation to the Y* axis(which is I assume what you are really trying to get around).
    Well I shot.. did I hit anything?
    *and possibly Z, depending where the tram error is
    May 2011
    Murray Bridge S Aust.
    5,959
    Happy Birthday Baron J. The theory of it sounds excellent, but before you go to far, I'd be inclined to do a test, fly cutting, as the head is slightly out, depending on the width of cut, you will end up with hollows (waves) going across your plate. What type of mill is it?
    Nov 2008
    Perth WA
    6,459
    Birthday greetings BJ.
    From the size of the bolt holes I imagine the head of the mill doesn't require a block and tackle for removal. Would there be less rooting around scraping the mating surfaces of the head and column into alignment? My suggestion obviously flops into a hole if the column is round.
    BT
    Jul 2010
    9,088
    Hi BT,
    Yourself and BJ seem to be assuming the nod error is at the column/base joint(I'm sure we have a better name for it than that.......interface? ). I think it could be one of three other places(or all of them )
    Why?
    Last edited by Stustoys; 1st Mar 2015 at 12:52 AM. Reason: changed my mind, three not four
    Ueee's Avatar
    Dec 2011
    Canberra
    40
    4,515
    Happy Birthday.
    I agree Stu, as if you are feeding with the X you will be fine, but as soon as you feed with with the Y you have problems, same with the Z.
    Nov 2008
    Perth WA
    6,459
    Hi BT,
    Why?
    Stu, I have absolutely no idea of what BJ's mill looks like. I assumed that the problem was the interface between the head and column not the column and base because Baron said the mill nodded. Heads nod.
    BT
    Jul 2010
    9,088
    BT
    hmmm I maybe reading things into the post that weren't there
    6,477
    Thanks for all the good wishes. The kids have been over and brought my granddaughter to see us. Lots of chocolate too. Yummy.
    I will take some photographs later and post them. In the meantime, the mill is the square column construction. Its the column that leans very slightly forward, or I assume that is where the lean comes from. If I use the tramming tool I can set the head to be spot on in the X direction. But if I turn the tramming tool through 90 degrees and check in the Y direction, I get about 3 thou deflection. This doesn't change if I lock the head gibs. Unlike the X axis. So when I check that I do it with the gibs locked.
    My theory is if I now use the Y traverse to face the plate then it should be parallel to the head. I only need to machine a strip slightly over 90 mm wide and 220 mm long for the vice to sit on. As it happens my fly cutter has a 92 mm swing, so I would need to use the Y traverse to do the facing.
    I hope I've got it right. I know that I should really take it all apart and put shims in, but its far heavier than I can manage.
    Oct 2011
    Norwood-ish, Adelaide
    59
    6,561
    I don't think that is going to work as you think. If you mount a plate and machine it with a fly cutter you will get the new surface square to the axis of the spindle but as Z is now not perpendicular to X and Y, you will get a saw tooth effect as you traverse the cutter to do subsequent passes (assuming you traverse along the long axis. If you traverse along the short axis you will get a series of scallops parallel to the existing table).
    The only way to fix the problem is to make it such that all three axis are perpendicular to each other - whether that be shimming or removing some material.
    Aug 2007
    68
    1,410
    In theaory, your very first job is to make sure the columns vertical dovetails are perfectly orthogonal to the mill table. I had to do on my Sieg X3 mill too when I bought it, you cannot expect this to be right from factory on such cheap machines. I found the interface between the mill base and the column was not flat - at the factory someone had used a hand rasp to tram the column.
    In practice, you probably will find that before you can tram the column you need to make sure the dovetailed part that slides up/down the column and where the mill head attaches to is properly fitted. Again in my case, the tapered gib had been fitted at the factory with a rasp. Only once that is done can you easily tram the column. Put an accurate square on the table, a magnetic DTI base on the dovetailed part that slides vertically on the column. with the tip of the DTI sense the vertical edge of your square whilst cranking the head up/down. Do this interleaving for x and Y axes. Either scrape or shim the interface between base and column until its right. Instead of a square you could make a cylindrical square on your lathe, provided its properly aligned not to cut taper. Or use an angle plate, but turn it over 180 degrees for each measurement to make first sure its really an accurate 90 degrees angle plate.
    Next step, you need to make sure the milling head is mounted orthogonally to the dovetailed plate that slides up/down the column. For that you put the DTI mag base onto the milling table, and measure in x and Y that the quill is orthogonal to the table. Scrape or shim where the head mounts as necessary. Of course, if you have a swivelling head, you first have to make sure the swivel axis is parallel to y on the table surface and orthogonal to X on the table surface.
    Before starting, of course make sure the table x and y dovetails are clean and properly adjusted, slightly to the tight side.
    near Rockhampton
    6,218
    This is probably an unsuitable idea as you said the mil is too heavy for you to disassemble it yourself. If you are unable to scrape the base to the column, you could always instead of making a sub plate for the vice, make a sub plate for the bed/column interface and longer bolts..
    Jul 2010
    9,088
    Now this I like. Assuming the error is at.the base/column. make a plate to suit, machine itas planned above, turn 180deg, bolt in place, job done(well ok, in theory job done).You should at worst be a lot closer and as RC says it.would.be easier to.tweek from.there.
    Ueee's Avatar
    Dec 2011
    Canberra
    40
    4,515
    That was what i was getting at, but with drawings it makes it easy to see.....
  15. #15
    6,477
    I promised some pictures of my mill.
    At the moment I've got the mill set up to cut out a 10 mm wide by 10 mm deep edge in a short length of 20 mm thick by 50 mm wide mild steel bar. I need these to hold down the new vice. I'll saw them to width later.
