Results 16 to 21 of 21
11th Feb 2015, 07:21 PM #16Member: Blue and white apron brigade
It's not just a matter of turning it down some sort of keyway or other locking arrangement will be needed. 3HP and a grub screw may not old all that well.
11th Feb 2015, 07:36 PM #17Diamond Member
- Aug 2006
- 1,106
I would never use a grub screw, I would be cutting a key way as per original.
12th Feb 2015, 07:07 PM #18Diamond Member
- Aug 2006
- 1,106
Ok, I'm starting to think a 90 frame motor would be the best place to start. I don't think there is a true bolt in solution out there.
The drill press has provision for the 165mm PCD, there is actually markings on the casting. I will just need to drill and tap.
Then the shaft will need to be machined to 19mm and a key way cut.
12th Feb 2015, 07:34 PM #19Most Valued Member
If you find a suitable motor but need the shaft turned down and a keyway done, I will be happy to help you out. Edit: I had to do a similar thing when I converted my mill to VFD with a 3 ph motor. Simon
12th Feb 2015, 07:56 PM #20Diamond Member
- Aug 2006
- 1,106
All right will keep that in mind if I get stuck, thanks for the offer.
12th Feb 2015, 08:02 PM #21
