Results 31 to 45 of 55
10th Jan 2015, 08:30 PM #31Most Valued Member
10th Jan 2015, 10:14 PM #32Cba
- Aug 2007
- 68
- 1,410
You are a FOOL!!!!
Sorry to offend you but I have to.
Only a fool can be so foolish, as to test a board with life mains components on a STEEL PLATE COVERED BENCH. Be very grateful to still be alive. You should NOT do this sort of work as you are clearly not suitably qualified.
PS: you did a nice job on the housing. But it is still not worth to risk your life. Go and buy a ready made speed controller.
10th Jan 2015, 10:31 PM #33Golden Member
- Sep 2009
- 666
Calling all electrical experts - DC motor conversion
I will take my chastising as its due. Appreciate the comcern though.
16th Jan 2015, 06:33 PM #34Golden Member
- Sep 2009
- 666
New plan. Turns out the lead I had to replace the board wants $250 for it, maybe not.
For that price I can buy a KB Electronics DC motor controller which will let me use a pot on it and get total variable speed control... So that's the plan.
Question: where is best to buy them from? Also what else do I need to set it up for my 2.5HP peak DC motor?
On a side note I finished motor mount. I didn't have any large plate so I cut 2 x 75mm wide lengths and TIG'd them together. I cut 2 x 10mm holes and used a Drexel with cutting disc to join them:
Then I welded the motor mount to the plate:
Fits perfectly and has about 1" of adjustment, plus it's much smaller than the AC motor on there now. Just needs a nice coat of gloss black paint.
Also got the remainder of my enclosure bits but now I'm changing the design again I may need another box unless I can use the original one again.
16th Jan 2015, 08:17 PM #35Cba
- Aug 2007
- 68
- 1,410
16th Jan 2015, 09:13 PM #36Golden Member
- Sep 2009
- 666
I don't disagree cba, but I don't have the budget at the moment for a 3 phase motor and VFD, whereas I currently have all I need to get the DC motor running, bar the PWM.
Is there another PWM you could recommend?
If this experiment with the DC motor doesn't work, a VFD is definitely next on the cards.
16th Jan 2015, 10:33 PM #37Member: Blue and white apron brigade
16th Jan 2015, 11:55 PM #38Golden Member
- Sep 2009
- 666
Everyone talks about cheap 3ph motors but I've never found one for less than a hundred plus.
17th Jan 2015, 12:08 AM #39Member: Blue and white apron brigade
Here's one for $50,.
http://www.gumtree.com.au/s-ad/horns...ase/1066053005
17th Jan 2015, 12:20 AM #40Golden Member
- Sep 2009
- 666
400v, don't I need 240v?
17th Jan 2015, 12:52 AM #41Member: Blue and white apron brigade
Technically yes but if you run a 420V 3Phase motor, connected in "star" or "Y" connection at 240V you will get about half the power.
So 3HP becomes ~1.5 HP but for a small Hercus like yours 1HP is more than enough.
More explicitly, that motor looks like its a 420V "Y" , or 400V "∆" 3HP
If you don't know what "y" and "∆" mean you will need to do a little bit of homework.
Running in Y Mode will give 420/240 = ~1.7HP
Running in ∆ mode = 400/240 = ~1.8HP
To get the full 3HP at 240V the Y connection inside the motor will need to be converted to ∆ connection.
This requires internal motor surgery and is not for the faint hearted or inexperienced to tackle
The ideal sort of motor for your lathe will have a nameplate like this.
These specs are the same as what I have on my hercus and I have only felt the need for more power than this a couple of times a year.
17th Jan 2015, 06:53 AM #42Golden Member
- Sep 2009
- 666
Got it. Thanks Bob.
17th Jan 2015, 06:58 AM #43Most Valued Member
Keep looking for 3 phase motors. They pop up from time to time real cheap. My motor on my VFD mill conversion was $40 brand new, the one for my lathe was $30. Both are 3 HP. I did need to re-wire them internally to bring out the star point though. The first time was interesting, after the sixth time it's routine.
Just have to keep looking.
17th Jan 2015, 07:59 AM #44Golden Member
- Sep 2009
- 666
Ok, on the look out for 3ph stuff now to see how that would pan out. Made an offer on that motor and waiting to hear back. Pricing up the DC motor drive and it's the same as a 3HP VFD delivered.
Also checking VFD options and have some questions.
1. Would I buy a VFD based on listed HP of the motor? Eg 3HP?
2. I would look to mount the VFD under the bench and then build a control box for it with my RPM display, will that work? Assume I can run a pot for the speed control.
17th Jan 2015, 09:21 AM #45Cba
- Aug 2007
- 68
- 1,410
1.
Modern VFD's (those not older than say 15Y) are very intelligent and adaptable. It is customary to have the VFD rating match the motor rating. Depending on application, it can be of advantage to have the VFD rated one or two size steps larger than the motor, especially if the rated motor power is required at elevated room temperatures and/or it is desired to run the VFD at the highest possible chopper frequency in order to reduce motor noise (or motor singing). Also Motor braking can be improved this way. Motor protection always remains fully assured. Downside of doing this is actually only the extra cost for a larger VFD.
That said, it is also perfectly possible to run a motor one or two size steps larger than the VFD. The motor output is then of course limited to the VFD rating. The downside of doing this is the extra cost, extra weight and extra inertia of the oversized motor, meaning reduced accelleration and braking performance. It will still perform better overall than the overrated treadmill motor setup you were looking at before. This is certainly not something you would do on purpose when buying new components. It is something that you can do in order to reuse existing components, or to make use of components that by coincidence just happen to be available to you at an irresistible price.
2.
Yes that would work very well.
PS: when buying a motor, also make sure the number of poles match your application. A 2-pole motor has about 3000rpm at base frequency, a 4-pole motor about 1500rpm, a 6-pole motor about 900rpm. The selection is a little different than it is with a DC motor. For example, a 4-pole motor will have the best power at about 1700rpm, but will remain usable up to at least 3000rpm, and it will provide constant torque down to about 500rpm with a cheap VFD and down to near standstill with a slightly more expensive "vector" type VFD.
Calling TIG experts - motorbike related.
By chancho196 in forum WELDINGReplies: 12Last Post: 25th May 2012, 11:19 AM
