Results 1 to 9 of 9
Thread: 3 PHASE TO 3 PHASE vfd
19th Dec 2014, 11:16 AM #1
WHATS THE POINT OF 3 PHASE TO 3 PHASE CONVERSION
http://www.ebay.com.au/itm/2-2KW-3HP...:SS:SS:AU:1120
19th Dec 2014, 11:18 AM #2Most Valued Member
- 4,258
variable speed
two ways to vary speed of motor...number of poles in the motor or vary the frequency...this is what a VFD does...varies the frequency
ps...works a treat on three phase...no good for single ph
19th Dec 2014, 11:55 AM #3
knobs
The seller also has a big range of knobs for projects
http://stores.ebay.com.au/superistor...4.l1513&_pgn=5
19th Dec 2014, 12:19 PM #4Most Valued Member
- Australia east coast
- 2,713
19th Dec 2014, 12:24 PM #5
We have maybe a hundred or more such VFD's at work. These are all on pumps. Some are automatically variable based on conditions sensed, some are on general winery use for transfers and enable us to set flow rates. Start slow then up to full speed until the end, then slow down for the finish. Shutting a valve on a slower flow is less likely to cause a rupture in the line. Another purpose is to use the ramp up to stop hammer in the lines.
19th Dec 2014, 12:24 PM #6Member: Blue and white apron brigade
19th Dec 2014, 03:23 PM #7Intermediate Member
- Sep 2014
- Australia
- 26
When I was on the tools, I used to wonder why anyone would want a single phase VFD Toys I tell ya!!
FWIW, I have only ever seen one single to three phase VFD ever and that was in a coin weighing machine in a casino.
19th Dec 2014, 04:39 PM #8Member: Blue and white apron brigade
19th Dec 2014, 05:26 PM #9Cba
- Aug 2007
- 68
- 1,410
People want VFD's for the same reason, as in the past 40 years you would not want to buy a handheld drill with only on/off and no variable speed.
- There is probably nothing on a machine tool, that you could not do without a VFD *(or another sort of variable speed control)
- but almost everything you can do either/or better, safer or faster with a VFD
*( it just happens, that nowdays a VFD is most often the cheapest means of variable speed control
Huanyang VFD - How to get single phase outputs from VFD 3 Phase output points (U,V,W)
By AP-R*D in forum METALWORK GENERALReplies: 14Last Post: 4th May 2012, 08:48 AM -
Hercus 3 phase lathe, single phase supply
By Pete F in forum THE HERCUS AREAReplies: 51Last Post: 16th Jan 2009, 10:15 AM
