Results 1 to 15 of 16
Thread: Fixed Steady Advice
27th Nov 2014, 11:17 AM #1
Fixed Steady Advice
I used my fixed steady today for the first time and I am unsure if this is normal. I have read the roller bearing otype do leave more marking than the brass tipped kind. However I think this excessive.
It is very think like guiding or flakes of fine tin foil. Very shiney almost chrome looking.
What did I need to do differently or correct??…..Live a Quiet Life & Work with your Hands
27th Nov 2014, 11:48 AM #2Cba
- Aug 2007
- 68
- 1,410
It could be one or more of the following:
- you have applied excessive pressure on the fingers?
- the workpiece was excessivley heated by cutting, and has expanded onto already tight fingers?
- the ball bearings may be worn and prone to seizing?
- you have allowed chips to fall onto the track of the ball bearings? That is the greatest problem of having bearing tipped fingers on a steady. Chips and metal dust tends to be rolled between bearing outer race and workpiece and can build up onto the workpiece therby increasing finger pressure and causing scoring.
- are you using too high an rpm? Consider that the rpm of the bearing depends on the relation between workpiece circumference and bearing circumference - looking at your pic this relation is easily 10:1. This means if you were to spin the workpiece with 2000rpm, the finger bearings would spin with 20,000rpm. And that may be too much, especially if you did not lube them for a long time.
27th Nov 2014, 11:50 AM #3
Hi Dale, It wasn't off center or too tight by any chance?
27th Nov 2014, 12:00 PM #4Most Valued Member
I'd say there is something wrong with the way you set up the steady. Did you just clamp the bar in the chuck, wind the fingers in and go at it?
You need both ends of the bar pretty much on the spindle axis.(the shorter and larger the bar the closer you need to be)
There are likely a dozen different ways to go about it.
If the bar is running true at the chuck you can set the steady up there and then slide the steady along to where you want it. You'll want to loosen the chuck to let the bar move if it needs to. *
You can use a DTI on the far end of the bar with the chuck just nipped and bump the end to get it running true(without the steady fingers touching it of course).
If its a heavy/long work piece you can sit it in the steady and scribe a circle on the end of the bar and move the steady to line the center of the circle up to a center in the tailstock.*(havent used that one)
*these methods assume that certain other parts of the lathe are inline.Last edited by Stustoys; 27th Nov 2014 at 12:25 PM. Reason: forum having issues and lost half my post
27th Nov 2014, 12:15 PM #5
Ray I centred it up against the chuck then moved it down to the end.
The item is the pillar from a drill and was being lightly sanded, so not hot from cutting etc.
No chips to start with.
It hasn't been used in years and as the Colchester is the only thing left at my parents after the moved I forgot to bring any oil. so that may be a possibility
I wound the fingers in until I felt them press firmly the knurled section is very large so I may have applied to much force unknowingly. How much is enough but not too much???…..Live a Quiet Life & Work with your Hands
27th Nov 2014, 12:17 PM #6
Come to think of it I was using the 3 jaw chuck and it is running out so that would put the steady out in relation to it.
27th Nov 2014, 12:20 PM #7
Also for reference the lathe is a Colchester Master 2500 (4ft Bed)
28th Nov 2014, 12:15 PM #8Most Valued Member
- 4,890
Going by your method of set up , can I take it that you didnt indicate the job in your 3 jaw.
If by some chance you did did you then indicate the outer end of the job.
If by some chance you did indicate the outer end of your job did you re indicate it after fitting the steady.
If you by some chance did indicate the outer end of the job when fitting the steady did you adjust the fingers to get the outer end of the job running true.
If by some chance you did not indicate the job in the 3 jaw or the outer end of the job before fitting the steady or even after fitting the steady I would say that the majority of your damage has been caused by the job not running true and trying to walk its way out of the chuck and steady.
Was there a centre fitted to the outer end of the job,if so you may of been fortunate that the job didnt come out of the chuck.
Your method of fitting the steady is to a point somewhat normal practice but relying on the inner end ( chuck ) running true to the outer end should not be considered, both ends need to be running true for this method and then still an indicator used when adjusting the fingers to confirm that nothing has moved.
28th Nov 2014, 01:51 PM #9
Pipeclay no indicator was used.
A longwinded answer but I see a proper set up is required for even simple polishing job. Thanks for the best practice methodology…..Live a Quiet Life & Work with your Hands
28th Nov 2014, 08:49 PM #10
steel
What grade of steel is that ? The swarth looks weird ? The tool appears to be tearing the work .
Mike
28th Nov 2014, 08:52 PM #11
It is the pillar from a 1940 waldown. No idea of the actual steel.
28th Nov 2014, 08:58 PM #12Most Valued Member
- 4,890
28th Nov 2014, 10:36 PM #13
28th Nov 2014, 10:43 PM #14Most Valued Member
- Sep 2011
- Ballarat
- 3,103
I have no doubt you have checked this already Dale but I have to ask.
None of the bearings on the steady had stopped turning during the job even though they might all be turning now.
Sometimes a bit of crud can jam them and stop them turning.
Just a thought.
Phil
28th Nov 2014, 11:29 PM #15
Strange ! It looks to me as though the lip on the work next to the steady has been running against the faces of the bearings. You can see rub marks on the steady fingers. It might also explain the torn up edges.
Just my 2 cents worth.Best Regards:
Dialling in long shaft on fixed steady
By YarrD in forum METALWORK GENERALReplies: 12Last Post: 13th Dec 2013, 11:14 PM -
VICTORIA Fixed steady rest for 12" lathe
By Greg Q in forum METALWORK - Machinery, Equipment, MARKETReplies: 3Last Post: 31st Aug 2013, 12:22 AM -
fixed steady
By morrisman in forum METALWORK GENERALReplies: 9Last Post: 24th Feb 2013, 09:31 AM -
Fixed Steady Identification?
By Metalman in forum METALWORK GENERALReplies: 1Last Post: 3rd Apr 2012, 11:58 AM -
Home made fixed steady
By morrisman in forum METALWORK GENERALReplies: 0Last Post: 1st Dec 2011, 07:59 PM
