Results 1 to 3 of 3
Thread: tool post
23rd Nov 2014, 08:37 PM #1Novice
- Jun 2014
- scone
- 14
tool post
Hi everyone, I am in need of some help. I have just brought a small lathe (al330) and intend to buy a multifix tool post from create tools, I am hoping someone can advise me on size I have also brought a mill and need to learn to use it, can anyone suggest some good books thanks in advance
23rd Nov 2014, 08:50 PM #2
How wide is the compound?
I'd be thinking an A size would be fine.
Milling a complete course by Harold Hall is a good start, but Youtube is truly your friend in this regard.
23rd Nov 2014, 09:55 PM #3Member
- Jul 2014
- eindhoven the netherlands
- 69
multifix ?
Sure you mean a multifix?
Multifix is a brand name and and system name.
The brand Multifix is the most expensive you can get.
The system multifix is the about the best you can get.
Or do you mean any type of toolpost with changeable tool holders?
Availability of cheap holders should be a point in your decision as you will need/want more of them.
As for size: the bigger the better, unless you are planning on working on tiny pieces.
A bigger one will take bigger, and therefore more rigid, tools.
Not that you will be able to take heavier cuts as the sideway overhang will be bigger but it will give you the possiblity to use a wider range of tools.
I have two 10 inch south bend lathes.
The light 10 has a type a rapid system fitted, the heavy 10 a type b that i had lying around from a bigger lathe i used to own.
Most special tools, knurling, parting, threading, boring bars, i have, do have a bigger shank and will only fit the type b.
cheers
jan
Parting tool mounted on rear tool post advice needed
By colbra in forum METALWORK GENERALReplies: 17Last Post: 12th Feb 2012, 02:49 PM -
tool post tart up
By toolman49 in forum METALWORK GENERALReplies: 3Last Post: 25th Feb 2011, 02:53 PM -
Hercus 4-way tool post dwg
By neksmerj in forum THE HERCUS AREAReplies: 4Last Post: 29th Mar 2009, 11:22 PM
