Page 2 of 2 FirstFirst 12
Results 16 to 24 of 24
  1. #16
    7,188
    I like Rays summary and agree the wow-wow sound is a strong sign the run coil is gone.
    I notice you tried to start it "by spinning the wheel".
    Just in case, try removing the wheel and rotating the shaft, as the wheel itself may represent too high a starting torque for a manual type start.
  2. #17
    May 2012
    Oakleigh, Victoria
    55
    By some unlikely coincidence both my lathe and compressor died with similar symptoms on Sunday.
    Compressor would start slowly and stall once pressure started to build up.
    Lathe would spin up very slowly and maybe come up to full speed eventually.
    Compressor is definitely the run cap, it's spilled it's guts.
    I suspect the the lathe is the same but I have to pull it away from a wall to get at the cap.
    Anybody know what the cap specs are for an AL320G ?
  3. #18
    6,473
    A few years back my chop saw developed that symptom and just stood and hummed without spinning up !
    Now its one of those motors without a centrifugal switch, the capacitor is permanently in circuit. Getting a new cap was no problem at all. But it didn't fix the problem.
    At the time there was a motor rewind shop just down the road and I took the motor there. The following day the guy who I went to see, phoned and said to come and pick the motor up. It turned out that the run winding had a break in the wire to the terminal block and only the fabric of the insulation was holding the wire in place. The conclusion was that mechanical fatigue due to vibration during use had caused the wire to part company with the brass ring that secured it to the terminal.
    So its worth having a very close look at any wires that are effectively unsupported.
  4. #19
    Jun 2008
    Lindenow
    50
    869
    Quote Originally Posted by P J View Post
    Second post in this thread will answer your question.
    http://www.woodworkforums.com/showthread.php?t=188669
    Matt
    Warning Disclaimer
  5. #20
    May 2012
    Oakleigh, Victoria
    55
    All sorted now.
    I popped into Hare and Forbes yesterday, they didn't have caps on the shelf but they couriered me a set to me today.
    Original
    Start cap 250 VAC 50-60Hz 100uF
    Run cap 450VAC 50-60 Hz 25uF
    Replacement values are a little different, but I got the feeling that they sell of lot of this combination.
    Start cap 125 VAC 50-60Hz 108-130uF
    Run cap 450VAC 50-60 Hz 20uF
    New 65uF run cap fixed the compressor too.
  6. #21
    Aug 2010
    Near Bendigo, Victoria, AUS
    72
    3,104
    Crikey! Don't expect the starting cap to last long! At a 125V rating and getting belted with 240V every time you start the machine, it will probably pop it's top in just a few starts..... send it back and get at least a 240V one.
    Cheers, Joe
  7. #22
    6,473
    I agree ! Unless that is a typo You need a minimum working voltage of 240 VAC for that cap, preferably 380 VAC.
    We are using 230/240 VAC here in the UK and the caps are usually 380 and 550 VAC working voltage.
  8. #23
    May 2012
    Oakleigh, Victoria
    55
    Yeah, I figured as much.
    I had some urgent work to do so it had to go in.
    I'll order a correctly rated one and swap it out later.
  9. #24
    Jul 2009
    133
    http://au.rs-online.com/web/p/alumin...itors/0117215/
    should not be an issue tho, any motor winder will probably have them in stock
  1. Electric Motor
    By robbo37 in forum METALWORK GENERAL
    Last Post: 18th Jul 2014, 09:21 PM
  2. Help with electric motor
    By Woodlee in forum METALWORK GENERAL
    Last Post: 26th Feb 2011, 11:14 PM
