Results 1 to 4 of 4
5th Oct 2014, 03:55 PM #1New Member
- Oct 2010
- 5
Have a CNC Mill but want manual lathe...should I swap?
I've inherited a CNC Mill. It's a MAXNC10 desktop model in good working order and comes with built in card reader/controller + heaps of spare parts including a spare controller and a spare (used) motor. I've also got a separate PC running LinuxCNC with a direct connection to the mill via parallel port. Whilst it is in good working order the mill has been used in a production environment so it is definitely in used condition with lots of scratches, dings and general wear and tear. I'd describe it as a 6 / 10 cosmetically. I'll post some pictures shortly...
Whilst the mill is a cool toy to play with, what I really want is a small bench top type lathe (anything over about 350mm between centers should be OK).
Anyone have a view as to the worth of the Mill and should I just try to sell it as-is or is it worth trying to do a swap with someone who has a small lathe? A new MaxNC10 is worth around $1600 US in this configuration so I would have guessed this one is worth somewhere north of $500AUD and south of a grand but not really sure.
Open to suggestions...
5th Oct 2014, 08:01 PM #2Most Valued Member
Hi Bammo,
Are you considering selling because you have limited room or limited funds? I ask this because the first question that comes to mind is why not keep it AND buy a small lathe, but I'm sure you have your reasons.
I have no idea what your machine would be worth on the used market so can't help there but you may regret selling it later on.
5th Oct 2014, 08:10 PM #3New Member
- Oct 2010
- 5
Simon - the Minister of Finance says I can't have 2 toys at once taking up space in the shed! I really don't need/use the mill, it's a lathe I want.
5th Oct 2014, 08:23 PM #4Most Valued Member
Thats a shame. Well, if you have to prioritise then start looking for a lathe/mill combination!
Edit: Hang on there a minute. I just re-read you first post. You inherited the mill? Surely it's of sentimental value to you? I would suggest to her that you cannot bear to part with it but you need a lathe. Put the mill in storage some place that she won't see it and then buy a lathe.
Mill Users Manual
By haemish762 in forum METALWORK GENERALReplies: 1Last Post: 25th Oct 2011, 09:42 PM -
JAFO FWD32 mill manual
By Graziano in forum METALWORK GENERALReplies: 2Last Post: 27th Mar 2010, 11:52 PM
