Results 1 to 4 of 4
Thread: Tough Drill Press RPM Table?
12th Aug 2014, 11:55 PM #1
Has anyone got an RPM table for thses machines that they would care to share. No idea what the model number is but it is 3 phase and has a GMF Craftsman motor on it if that helps.
13th Aug 2014, 05:00 PM #2Most Valued Member
- 4,255
not hard to work out ...just need to know motor speed ...usually 1440 or thereabouts
Measure pulley od diameters
that is all grooves on Motor pulley, intermediate pulley sizes and spindle sizes
work out placement of belts
and then work out ratios of each arrangement...multiply motor by ratios
eg motor big step 4"
intermediate small 2''
Intermediate big 4"
spindle small 2"
(use OD where belt travels if belt sit deep inside V)
therefore 4/2= 2
assume motor speed 1400
then 1400 x 2 = 2800 and 2800 x 2 + 5600rpm at spindle
do that for each possible step
13th Aug 2014, 07:07 PM #3
Thanks and I know there are also calculators on the web that will do it but I was going the lazy option as I am pretty sure I have seen a printed label on some inside the belt cover.
13th Aug 2014, 08:29 PM #4Golden Member
- Sep 2008
- Riddells Creek, Vic.
- 831
A cheap non contact digital tachometer from ebay would be the easiest way to measure the speeds, they are also very handy to have around.
Tough drill press
By node105 in forum METALWORK GENERALReplies: 17Last Post: 5th Jun 2013, 05:06 AM -
Tough Drill Press (gloat)
By Bryan in forum METALWORK GENERALReplies: 49Last Post: 1st Sep 2011, 12:06 AM
