Results 1 to 12 of 12
10th Aug 2014, 01:21 PM #1Most Valued Member
- Aug 2009
- Sydney, NSW, Australia
- 1,844
I have an idea, tell me if im nuts!
hey guys ive found my self back at it again looking for another metal lathe to make wheel spacers for a motorcycle, the pic was my last conversion and the bike is hes now and i have a new bike to put road bike wheels on, now im on a limited budget or im just being a tight ass either one lol im looking at modifying one of these metal lathes CNC Metal Motorized Mini Lathe Machine | eBay it says it can machine up to 20mm diameter steel/aluminium but i think there over exaggerating now i have thought about it and do u guys think i could disconnect the electric motor and use a electric drill to connect to the chucks shaft hanging out the back of the unit? than i could just cable tie my drill at full speed and use a 240v hydroponic fan speed controller to adjust my speed do u guys think its doable?
i need to machine aluminium wheel spacers biggest being 25.4mm diameter and 29mm wide (width wont be a problem) with a bore size 17.1mm
10th Aug 2014, 01:44 PM #2Pink 10EE owner
- 6,218
10th Aug 2014, 02:00 PM #3Most Valued Member
- Aug 2009
- 1,844
yeah mate thats why i thought i'd use a power drill to connect to the chucks shaft, the drill will power the chuck so there should be plenty of torque from the drill powered chuck
hence me saying they over exaggerated the 20mm cutting material i doubt the little 70-150watt motors would cope
10th Aug 2014, 02:56 PM #4Pink 10EE owner
- 6,218
Takes more then just HP to make a machine.... it weighs just 3kg... it is too light to be much use for anything but wristwatch parts..
10th Aug 2014, 03:04 PM #5Most Valued Member
- Sep 2010
- Lebrina
- 1,915
Presumably you will want to bore a hole in your spacer. With only 135mm between centers, you will be very restricted in the drill bit that you could fit in there, if you can even mount a drill chuck.
Even if you do up the power by using your drill you will probably find a weakness elsewhere. At best those are only a model making lathe.
I think you will be very disappointed if you buy that machine.
Perhaps one of the small Sieg lathes would suit you better. You will be spending $800 odd dollars though.
10th Aug 2014, 03:28 PM #6Most Valued Member
- Aug 2009
- 1,844
Karl, yeah thats the issue im running into, a wheel set for my bike is $720 from NZ so trying to look for a cheaper alternative, i could buy a second hand lathe i just have no shed space to store it so it will be stored outside
10th Aug 2014, 03:32 PM #7Most Valued Member
Your nuts! Seriously though, I'm a big fam of getting the most of a machine and even getting more out of a machine than it was ever intended but TBH, at 3Kg, I can't see that thing doing what the seller claims, let alone what you want to do. I can understand that you are on a budget, I know that feeling but even the cheapest, oldest, clapped out, worn S/H machine would do a better job than the one you linked to, AND more. I would keep looking and buy a S/H lathe. Cheers, Simon
10th Aug 2014, 03:34 PM #8Most Valued Member
10th Aug 2014, 03:50 PM #9Most Valued Member
- Aug 2009
- 1,844
i just found a impressive video of one of these 6 in 1 lathes machining aluminium rod check out the video scroll forward to exactly 1 hour
https://www.youtube.com/watch?v=eyvfiMfWEkc
hey simon the wheel spaces vary and 8 will need to be made, its far to costly to have a machine shop make them
10th Aug 2014, 07:07 PM #10Most Valued Member
- Oct 2007
- 3,112
If you provide the material and a precise drawing of what you want made, if it's a simple turning and boring job I'm happy to make them for you.
Anything to stop anyone buying one of those "lathes".
Ever.
10th Aug 2014, 07:45 PM #11Most Valued Member
- Aug 2009
- 1,844
10th Aug 2014, 10:25 PM #12Cba
- Aug 2007
- 68
- 1,410
I would have absolutely loved one of those at age 10. Seriously. The most sophisticated tool I had back then was a hand drill, the ones with a handle to turn on the side. That was 50 years ago....
You can have a very similar machine but with better specifications, made in Austria. It is called "Unimat". Not the Emco Unimat, this is another Unimat. "Unimat Metal Line 6in1". If you look and compare, it is very similar to the China made item above. Unfortunately it costs a little bit more:
Unimat Metal Line 6 IN 1 Precision Desktop Portable Machine THE Cooltool | eBay
Here the YouTube link to videos showing the Unimat Metal Line in action:
TheCoolTool01 - YouTube
Then the Unimat ML
THE Cool Tool Unimat Metal Line 6 IN 1 Benchtop Tool Lathe Drill MILL | eBay
Also available with CNC
THE Cool Tool 160200CNC Unimat CNC 3D Upgrade SET | eBay
They also make a basic model with more plastic, called the "Unimat1 classic 6in1":
Unimat 1 Classic 6 IN 1 Benchtop Tool Lathe | eBay
This is the link to the manfacturer's site. You will be surprised. I am surprised. I did not think there is such a vast range of different models and options for this sort of machine. I am not sure anymore if this is a toy, or a teaching tool, or serious competition for small model making lathes like Sherline.
http://www.thecooltool.com/en/products/
Do not miss having a look at the CNC videos.
Opposing toothed "Clutch-Plate" Nuts? (a bit like "Castle" Nuts...)
By Batpig in forum METALWORK GENERALReplies: 6Last Post: 5th May 2009, 08:18 PM
