Results 16 to 18 of 18
12th Aug 2014, 01:11 AM #16Cba
- Aug 2007
- 68
- 1,410
Yes, still need a "run out" groove to start. I leave the half nuts closed for non-native threads, so no difference in this regard.
Yes if it is a deep shoulder you need to stop before hitting it when reversing, then turn the chuck manually (or slow down with the VFD or use jog). Agree it is a bit a hassle with those lathes that do not have variable speed nor a back gear to slow below 100rpm. If its only a shallow shoulder, I retract the cross slide far enough to clear.
12th Aug 2014, 09:44 AM #17Most Valued Member
- Australia east coast
- 2,713
12th Aug 2014, 03:13 PM #18
Hi Ewan,
Enjoyed watching your video. Neat trick. I made up an adjustable stop, and run low speed to do the same job, but the advantage of running the other way is better finish due to higher speed.
Just to clarify something, you can do metric threads on an imperial lead screw and disengage the half nuts.... the trick is knowing when to re-engage them, in other words which time around on the thread dial is correct.. If I recall correctly I think Stuart did the maths on how many revolutions were required.... it got complicated real fast... in the end it was obvious that it was easier to leave the half nuts engaged and reverse back.
Cutting Metric thread on AL-330
By Sterob in forum METALWORK GENERALReplies: 10Last Post: 2nd Dec 2013, 03:35 PM -
Metric thread on imperial lathe, without reverse.
By Vernonv in forum METALWORK GENERALReplies: 65Last Post: 7th Nov 2013, 09:32 AM -
Gear train to cut imperial threads on metric lathe (AL 340)
By 19brendan81 in forum METALWORK GENERALReplies: 11Last Post: 17th Jan 2012, 03:15 PM -
Metric threading on an imperial lathe
By Vernonv in forum METALWORK GENERALReplies: 9Last Post: 25th Oct 2010, 07:58 AM -
Metric Thread Cutting on Model 9A with Imperial Lead Screw
By Rodd Perrin in forum THE HERCUS AREAReplies: 3Last Post: 21st Sep 2009, 02:14 PM
