Page 2 of 2 FirstFirst 12
Results 16 to 18 of 18
  1. #16
    Aug 2011
    victoria
    499
    Quote Originally Posted by bollie7 View Post
    Is it possible to change the way you hold the workpiece and use a slitting saw in the vertical spindle, cutting from the side?
    bollie7
    I have think about it but the job is only 8mm dia brass and only 18mm long , if i leave the bar long to cut with the slitting saw then it will flex bad i think .
    Peter
  2. #17
    Oct 2011
    Norwood-ish, Adelaide
    59
    6,559
    If you sandwich the brass between the cutter and an angle block it should not flex away. I have (as probably do many others) a 1mm slitting saw that would do the job. If it is only one piece of brass 8mm diameter, 18mm long with a 6mm deep 1mm wide slot down the length I could even do it for you.
  3. #18
    Aug 2011
    victoria
    499
    Hi Michael.
    Thanks for your suggestion . i will try it . if i fail then i might take up your offer
    regards
    peter
  1. DONE: Darex endmill sharpening system. Air spindle
    By Greg Q in forum METALWORK - Machinery, Equipment, MARKET
    Last Post: 9th Sep 2013, 07:33 PM
  2. endmill sharpening
    Last Post: 4th Aug 2013, 10:59 PM
  3. Useful endmill rpm chart
    Last Post: 6th Oct 2011, 10:29 PM
  4. $530 endmill
    By Greg Q in forum METALWORK GENERAL
    Last Post: 24th Jun 2011, 09:19 PM
