Results 46 to 46 of 46
8th Aug 2014, 05:33 AM #46New Member
- Mar 2014
- Norway
- 3
The variator does need occasional adjustment to ensure there is no slippage under high torque conditions. It sounds to me like you have to adjust the swash plates a bit to eliminate this.
I can push a 28mm drill bit into 1021 carbon steel with a 10mm pilot hole and it won't slip. I use carbide and have made some very aggresive cuts to the point it turned the toolpost but never has the variator slipped.
Morrisman; thanks. Before I moved to Norway I only owned a bench grinder and a circular saw. The rest I have managed to accumulate here. Living so close to Sweden has been a huge plus as Sweden is a machinists Mecca.
Paul.
Chipmaster Thread Cutting
By Piers037 in forum METALWORK GENERALReplies: 24Last Post: 10th Aug 2013, 01:08 AM -
Colchester Chipmaster thread engagement lever problem
By achjimmy in forum METALWORK GENERALReplies: 10Last Post: 10th Jun 2013, 03:10 PM -
Colchester
By pjt in forum METALWORK GENERALReplies: 18Last Post: 8th Jun 2012, 02:38 PM -
Toowoomba:colchester chipmaster lathe $1495
By damian in forum METALWORK GENERALReplies: 5Last Post: 16th Feb 2010, 11:40 AM -
Colchester
By footz in forum METALWORK GENERALReplies: 18Last Post: 1st Oct 2008, 10:42 PM
