Results 76 to 90 of 100
Thread: New shed. Buy or build
19th Nov 2014, 06:46 AM #76Most Valued Member
Hi phil. That lathe really does look well cared for! What I was trying to say eatlier was that for a short term solution it looks pretty darn good!
PS. Only at the resort for 2 days. Its just a topover on our way to Fraser Is. It will be camping for us there..... which is what I prefer!
19th Nov 2014, 08:02 AM #77
Phil I hope the girl has still gone on and done something for her sake.
Thanks for the offer Phil, they would fit mine by the looks as they are quick release but if you can find a local TAD or a place that does repairs etc the are always after parts.
The frame looks quite adjustable and low set although it doesn't fold up, mine is normal and just right for me to get up and out of. I guess its alloy light as and those axle mounting blocks I am sure could be used somewhere.
The swivel front wheels mount could come in handy if you mount it with a work light in it I have 2 to make here. The tube off the frame if you were wood turner I have made tool handles out of my old wheelchair. Front castors ideal for a large steady. LOL sorry I don't see waste I see possibilities.
19th Nov 2014, 08:34 AM #78Most Valued Member
- Sep 2011
- Ballarat
- 3,103
Hi Ray,
the wheels are yours, I think transport may even have been arranged.
You have given me some ideas with the rest of the stuff though. My daughter has requested a sports drink holder for her chair and she is starting to nag me now .
The young girl I am sure has gone on to do what ever she wanted to do. She certainly wasn't a shrinking violet
Phil
19th Nov 2014, 08:45 AM #79
Phil your a top bloke let me know the cost please, now how did you know where to send them
Well now the workshop is set up get cracking daughters can be very annoying when it comes to requests left outstanding
Edited to ask Q
Phil on an idea I have had for the spare wheel hubs I have, being they are sealed bearings and stand up to some gruelling punishment would the bearings and hub make a reasonable drill mount for the lathe?? If I turn a shaft much like the axle and fit a Jacobs Chuck or small keyless chuck Thinking out loudLast edited by wheelinround; 19th Nov 2014 at 08:58 AM. Reason: To add idea
19th Nov 2014, 09:42 AM #80Most Valued Member
- 4,258
Geez...you'll be a lot lot older than the wooly mammoth that they found in Russia...and believe they might be able to clone...that was only only 50000 yrs tho
at 16billion you aint going to be able to cloned so stop dreaming about the new shed...go get one ASAP before its too late
I think what you have made for your self now is better than the container idea tho...albeit less security.
19th Nov 2014, 03:11 PM #81Most Valued Member
- Sep 2011
- Ballarat
- 3,103
Hi Ray,
we have a forum member visiting Ballarat and he has offered to take them back with him.
Not sure about the hubs as a drill. The direction of the load on the bearings in a wheelchair is entirely different to the direction of loading in a drill press type situation.
Still that also depends on how blunt the drill bit is.
Phil
19th Nov 2014, 06:24 PM #82Most Valued Member
- Australia east coast
- 2,713
WRT insulation, you may not be aware that Bradfords make a foil board insulation product in various thicknesses. It is polystyrene rated for house insulation so doesn't support combustion, with aluminized paper glued to both sides. 2400 x 1200 sheets in various thicknesses. I've used quite a lot of the 30mm thick stuff to insulate my boat and the cathedral ceilings of my cottage. It's reasonably stiff and you could easily attach it to the underside of the iron roof.
It'll make a *huge* difference to the heat transfer.
PDW
19th Nov 2014, 06:32 PM #83Most Valued Member
- Sep 2011
- Ballarat
- 3,103
19th Nov 2014, 06:37 PM #84Golden Member
- Jun 2005
- Helensburgh
- 618
I built a shed extension with my dad when money was a bit short and certainly was not going to extend to a concrete slab. Dad got around this by scrounging second hand bricks form wherever and topped them with a layer of concrete to smooth it out. It was still going strong twenty years later when we sold the place. The bricks had a lime concrete mix broomed into them and hosed to lock them together before concrete was laid over the top. He said that a lot of old factory floors were done this way way back when.
Containers appeal to me for a lot of reasons and some nifty houses have been built from them What puzzles me is why a slab would be needed to put one on when they are designed to be supported on the four corners. Surely put four piers down and drop it on is sufficient?CHRIS
19th Nov 2014, 06:42 PM #85
19th Nov 2014, 06:45 PM #86Philomath in training
20th Nov 2014, 07:40 AM #87
20th Nov 2014, 08:18 AM #88Senior Member
- Nov 2011
- Port Sephens NSW Southside
- 123
Wheels
RayWill drop them off tne end of next week.JohnQ
20th Nov 2014, 03:35 PM #89
20th Nov 2014, 10:07 PM #90Senior Member
- Nov 2011
- 123
Phil
Thanks for coming in the work today, to deliver the wheels. Exspecially seeing you are on holidays.
Also thanks for showing us a few of the sights.
John & Debbie
