Results 31 to 42 of 42
Thread: Gears, gears and more gears
16th Jul 2014, 01:48 PM #31Most Valued Member
- Oct 2007
- 3,112
I've only ever cut gears on a horizontal arbour but provided the setup is rigid I wouldn't bother with the slitting saw, just feed slowly.
16th Jul 2014, 04:09 PM #32
problem
Turns out the gear is part of the whole cone sleeve assembly .
Dont know what to do ? Maybe I can machine the gear teeth down and then shrink on the new gear .
16th Jul 2014, 06:18 PM #33
gear
Managed to turn down the gear. So the next step is to make the new gear and shrink it onto the sleeve
I used the pipe centre I made at TAFE years ago
16th Jul 2014, 07:39 PM #34Most Valued Member
- 4,890
Seeing that you have the centre of the cone pully out,is it possible to shrink the gear blank onto the spindle and then cut the teeth.
16th Jul 2014, 07:44 PM #35
16th Jul 2014, 10:00 PM #36Pink 10EE owner
- 6,218
With regards to the shrink fit, just be careful no parts get cracked etc... I would go for a nice sliding fit and loctite... If I wanted more strength I would put small pins into blind holes drilled through the tooth gullet..
I have gone to the liberty of drawing up the 10dp 24 tooth gear and placed 4 holes in the tooth gullet...
They are sized, 2mm, 2.5mm, 3mm and 4mm.. The 4mm is borderline too big as the hole extends up the tooth somewhat, but the 3mm looks about right...
Just another option..Gold, the colour of choice for the discerning person.
16th Jul 2014, 10:59 PM #37
I had another look at the photo of your spindle with the original gear. It looks as though that was not machined in situ against that shoulder. It also looks like there is a line just inside the gear. I wonder if the gear is actually part of a spigot or sleeve that's pressed or shrunk into the spindle. Consider that option too. I think it may be difficult to mill the gear next to that shoulder? Or am I missing something?
Cheers, Joe
17th Jul 2014, 12:41 PM #38
18th Jul 2014, 12:46 AM #39Golden Member
- Nov 2010
- Gippsland Victoria
- 733
18th Jul 2014, 01:21 AM #40
Mike, my last post doesn;t make any sense now that I can see the photo in post 32. For some reason it wasn't showing at my end. So my comment was really related only to the last photo in Post 27. Sorry.
Cheers, Joe
18th Jul 2014, 08:16 AM #41Pink 10EE owner
- 6,218
22nd Jul 2014, 12:41 PM #42
1954
1954 BUT COULD BE INTERESTING
http://www.hobbycnc.ru/docs/GearCutter___Winton.pdf
Making Gears
By Chris Parks in forum METALWORK GENERALReplies: 10Last Post: 4th May 2014, 01:17 PM -
Cutting gears?
By neksmerj in forum METALWORK GENERALReplies: 17Last Post: 18th Mar 2011, 06:22 PM
