Results 1 to 15 of 26
Thread: Protection close to sea
28th Jun 2014, 06:29 PM #1Intermediate Member
- Dec 2010
- 79
- 31
Afternoon
I will be storing a metal turning lathe in my garage for my son for quite some time.
We are very close to Western Port bay ( about 60 metres) would lanolin spray be good to cover all the slides etc. with? if not please can I have some suggestions.
28th Jun 2014, 07:57 PM #2Golden Member
- Dec 2011
- 505
I have found lanotec brand spray lanolin good for controlling corrosion on the boat, and in the shed.
Just get a decent coat on all surfaces and it should be fine. For extra protection, spray with lanolin and when it is dry but still tacky put flexible plastic film directly on the surface with no air between plastic and surface. That will keep it dust free as well. IME dust seems to attract and hold moisture.
Bill
28th Jun 2014, 08:29 PM #3Golden Member
- Aug 2012
- Australia
- 645
Everything rusted in my garage. Enter Lanolin, now nothing rusts. Can not speak highly enough of it. All my machine tools get cleaned and sprayed with lanolin. A quick spray of WD40 removes it. No hassle at all and not a speck of rust.
The big difference between lanolin and say WD40 or oil, is that when it dries it forms a wax like layer rather than evaporating over time. I have bored engine blocks then sprayed once. Two years later and no sign of rust.
28th Jun 2014, 08:43 PM #4
Another cheap - and hand friendly - option is vaseline.
28th Jun 2014, 09:01 PM #5.
- 6,459
28th Jun 2014, 09:12 PM #6Member
- Dec 2010
- Mornington Peninsula
- 97
I also live on the Western Port Bay side of the Peninsula, though no where near as close to the water as you. I use lanolin spray, and recommend it.
28th Jun 2014, 09:59 PM #7Senior Member
- Jul 2007
- 332
Another option
LPS 3 is another option and dries to a somewhat tacky wax (without smelling like sheep) and is good for long term storage, LPS 2 is a bit lighter duty and both should be available from the likes of Coventry's. Just remember to give the container a shake before use as all the good stuff seems to settle over time.
28th Jun 2014, 10:16 PM #8Pink 10EE owner
- 6,218
I could also offer an idea of covering it with a painters cloth.... I have been covering my machines with them...
28th Jun 2014, 10:53 PM #9Most Valued Member
- Australia east coast
- 2,713
Yes, this helps quite a lot. My place in Tasmania is very dry even though I'm right on the water's edge due to the direction of the prevailing winds so rust isn't really a problem - the weld seams are still bright metal after 2 years. However during the change in seasons there are a couple weeks where I get some condensation on bare metal surfaces in the shed, and drop cloths (plus lanotec) keep the rust from forming.
Near the coast in Sydney was much, much, much worse - higher temperatures, higher humidity and onshore winds instead of offshore ones.
PDW
28th Jun 2014, 11:12 PM #10.
- 6,459
All my machines are and have been shrouded in cotton sheets. The Douglas shaper was covered in the oilest sheet and a blue tarp. To no avail. Now the seldom used stuff, the Douglas included, is anointed in red Timken wheel bearing grease. Red, because I can see what has been anointed.
BT
28th Jun 2014, 11:13 PM #11Most Valued Member
- Oct 2010
- melbourne, laverton
- 1,910
easy
hi mate crc have a product called, soft seal. Its actualy made for the long turn protection of steel.
https://www.blackwoods.com.au/part/0...-aerosol-300gm
I use it it works.
aaron
28th Jun 2014, 11:16 PM #12Member
- Jul 2012
- Malvern East
- 84
G15
A product i use is G15 from australian inhibiter and wrapped in there film it will be safe for years to come
Also cannot speak highly enough for the lanotec stuff but if i need to ice something i use g15
http://www.australianinhibitor.com.au/page/1/home.html
Bruce
29th Jun 2014, 07:58 AM #13Most Valued Member
- Sep 2011
- Ballarat
- 3,103
Wow what a timely thread. Our landlord has decided it is time to move back into her house (well after the VCAT hearing coming up shortly) and thanks to a 'leg up' from family, we are purchasing a house. Amazing how long it takes to be able to do this again when you have an ex wife.
Thing is there is a decided lack of shedding and I was pondering what to use to cover the machines.
I pretty much decided on Lanotec products on account of how well it does on the steam engines at work.
Now I am definitely going to use it after reading these replies.
I also have a can of the Soft Seal that I use if I do machining for friends and they are tardy picking it up That stuff works well but for the price I'll stick with the Lanotec.
Phil
29th Jun 2014, 11:05 AM #14Golden Member
- Aug 2012
- Australia
- 645
29th Jun 2014, 12:04 PM #15Golden Member
- Mar 2009
- 54
- 825
When I store stationary engines away, I give them a good wipe over with normal oil, pack a couple of dry pack desiccant bags in strategic places then cover them with a flannelette sheet and this seems to work pretty good.
If you can get some, steam cylinder oil is the ducks nuts when it comes to rust inhibitors but it's not easy to buy these days unless you want a 44 gallon drum of the stuff.
If you are putting your gear into long term storage a sealed plastic cover is probably better than cloth or use a motor bike cover as these keep moisture out but will also breath.
If you want to pick up some desiccant packs give me a yell as all the equipment we get delivered at work comes with them.
Greg.
