Results 1 to 4 of 4
24th Jun 2014, 10:17 PM #1Intermediate Member
- Nov 2012
- Belgrave, Victoria, Australia
- 26
Supplier of high speed steel and tool steel bar and spring steel in melbourne?
Hi all,
I was wondering if anyone on here knew of anywhere to get a couple of meters of 5mm square hss and w1 bar stock in Melbourne? (preferably without it costing the earth).
I was also curious as to whether anyone had any sources for spring steel sheet up to about 1mm thick in melbourne?
Any help would be very much appreciated.
24th Jun 2014, 10:28 PM #2
I could probably help you with the spring steel I've got 1095 in 20 thou ( 0.5mm) and some others here on the forum have 25 thou and 32 thou plate. Depending on how much you want, you can sacrifice handsaw blades, they will cover up to 40 thou ( 1mm).. You'll struggle to find a Melbourne supplier, but if you are going to ring around, try asking for spring steel blue shim stock.
For small amounts try here http://www.victornet.com/cgi-bin/vic...teel:1523,1524
25th Jun 2014, 09:21 AM #3Intermediate Member
- Feb 2013
- 33
The couple of times I've recently used crinoline flat spring steel for service loops, Dawborn Steel in Huntingdale, Melbourne offered the best service, they will slit the width required, probably a minimum order charge.
25th Jun 2014, 12:44 PM #4Most Valued Member
- Oct 2010
- melbourne, laverton
- 1,910
sping steel
this company.http://www.sssprings.com.au/
Ive brought spring steel from them before.
they were very helpful.
id give him a ring
aaron
Cuting High speed steel??
By iron bark in forum METALWORK GENERALReplies: 29Last Post: 26th Jun 2013, 03:01 AM
