Results 16 to 30 of 36
18th Jun 2014, 03:03 PM #16Senior Member
- Sep 2007
- Melbourne, Australia
- 149
I was thinking either a 5 inch or 6 inch.
18th Jun 2014, 03:28 PM #17Most Valued Member
- 4,890
Do you have the ability to finish machine a back plate to suit the chuck that you eventually get?
18th Jun 2014, 03:30 PM #18Member
- Jul 2012
- Malvern East
- 84
Here it is
http://littlemachineshop.com/product...ProductID=1922
Off the shelf apparently But seriously turn the chuck back plate down in thickness add a register dia and bolt or new chuck to the old it has no mass to speak of
Good Luck With it
Bruce
18th Jun 2014, 03:51 PM #19Most Valued Member
- Australia east coast
- 2,713
Yes, it's a complete POS and belongs on a wood lathe at best.
Sorry but really that's the poorest excuse for a metalworking 4 jaw chuck that I've ever seen. Closer to a faceplate.
Having said that, Joe is quite right - you could make some soft jaws up for it and bore them to whatever ID you need. You certainly can't do worse.
PDW
18th Jun 2014, 03:57 PM #20Senior Member
- Sep 2007
- 149
18th Jun 2014, 04:04 PM #21
Oh boy. I'm glad I asked you to photograph that.
That looks a lot like a woodworking chuck (construction ) to me. I too would give up on that. The jaws are only supported (prevented from tilting out or in under pressrue) by the washers under the nuts.
I actually can;t see how the chuck body is held concentrically....
I really agree with the above comments: try and find or buy a new chuck with the jaws held in proper tracks in the chuck body - not just elongated bolt holes.Cheers, Joe
18th Jun 2014, 04:04 PM #22Most Valued Member
- 4,890
If you have a chuck in mind already,I can make a semi finished backplate for you.
If you need the back plate finished that can be done as well.
The chuck would need to be supplied for final fitting.
18th Jun 2014, 04:13 PM #23Senior Member
- Sep 2007
- 149
haha. yeah. I've been informed on how bad it is. I'm quite embarrassed, but that is what came with the lathe.
That's very generous of you Pipeclay.
Where are you located?
I'm considering this 4 jaw chuck.
http://littlemachineshop.com/product...2338&category=
18th Jun 2014, 04:30 PM #24
Because of the weight - shipping from the US might be quite costly! I suspect that could find something at a similar price in Melbourne. Give Melbourne Tool in Campellfield a call. They often have specials - I've been watching there too....
Cheers, Joe
18th Jun 2014, 04:35 PM #25
...and then there is this beauty! http://www.ebay.com.au/itm/321434085946
Someone here could make you an adapter or backplate to suit your spindle thread, I'm sure.Cheers, Joe
18th Jun 2014, 04:38 PM #26Senior Member
- Sep 2007
- 149
Yes, you're right, shipping is just on $100 for that chuck.
I am looking locally too. The backplate is the main issue however. The chuck can be had from most places fairly easily.
18th Jun 2014, 04:52 PM #27Most Valued Member
- 4,890
You may of miss understood my reply,I can make it but there would be a cost.
The chuck you listed would run out around $170US.
Mick moyles in Sydney has a 6" new for $154.
As said you maybe able to locate one in Victoria for similar pricing.
The one listed on ebay already has the thread to suit a Hercus lathe,if you use this it would require a back plate to be fitted to it and then either 3 or 4 tapped or through holes put into the chuck itself to accommadate the back plate.
18th Jun 2014, 05:00 PM #28Senior Member
- Sep 2007
- 149
No no, I understood that there would be a cost. I will keep looking. Once I find an appropriate jaw I will let you know. Probably will be within the next few days. Then we can discuss cost.
i will buy that backing plate from littlemachineshop with the m39 thread already.
18th Jun 2014, 05:02 PM #29Most Valued Member
- 4,890
It would probably be cheaper to have it made here,when you take into account shipping.
18th Jun 2014, 05:10 PM #30Senior Member
- Sep 2007
- 149
