Results 1 to 10 of 10
Thread: Qualos 00 gear hobber
7th Jun 2014, 10:33 PM #1Diamond Member
- Mar 2014
- South of Adelaide
- 1,227
here my latest toy, a Qualos 00 gear hobber. Sorry about the dodgy photo, i pick it up Wednesday and its still in the trailer. I'll post better picks later when i can get it out the trailer.
According to the card that was velcroed on it was made in the 1930's and was used for making gears in water meters. At some point it wound up in a scrap yard where the former owner of Chains and Accessories bought it and restored it as a demo machine/office ornament. Its only got 5 change gears with it so i will have to make some more. I'm hoping i can use the gears i have to make some of the ones i don't have and eventually make a full set. So far I've found out it will cut a maximum 3.5" diameter gear and It uses 5/16" bore hobs which i think might be hard to get. If any one has a copy of a manual or any sales literature i would be keen to get a copy of it. I'll post more pics and info as i get things sorted.
7th Jun 2014, 11:02 PM #2Philomath in training
- 6,563
I looked at that machine but decided that it was a bit small for what I did (although would probably do most) and was way too expensive (noted the crossed out tag). Well done. let me know if there are gears I can help with.
8th Jun 2014, 09:15 AM #3Diamond Member
- Mar 2014
- South of Adelaide
- 1,227
Its a bit small for me too but i've got a couple of things i can use it for. The prices on the machines were high to deter people just bying them because they are cheap and competing with Hercus. In the current economic enviroment i can understand why they did that. When i talked the the bloke selling it and told him i wanted a hob just so i could learn how to use one he dropped the prices a fair bit for me. I was seriously thinking of buying the hercus Hobber but it was in pieces and didn't have any change gears so i bought the little Qualos hobber. He also tried really hard to sell me the big slash grinder but i just don't have the room.
10th Jun 2014, 10:01 PM #4Diamond Member
- Mar 2014
- South of Adelaide
- 1,227
More photos
Finally got it out the trailer and into the shed.
I've measured up the change gears and they appear to be 24DP, I've just got to figure out the pressure angle now so i can try and source a hob. The change gears i have are 90,72,30 and 2 20tooth. with those gears and the ones i cut as i go i can cut another 7. I i use a compound gear train i think i can cut a few more also.
Above are the photos of the collet that goes in the spindle, as can be seen in the photo its busted. It looks like a C type collet but it is too big for a C1 and too small for a C2. I think it might be some thing qualos made up. I'll keep searching for some collets to match but i think I'll have to make some and an arbor of some sort.
10th Jun 2014, 10:53 PM #5Philomath in training
- 6,563
You can make your own hobs -
http://www.woodworkforums.com/showth...78#post1661078
Alright, it's being used to do a worm wheel there but the same applies.
12th Jun 2014, 08:31 PM #6Diamond Member
- Mar 2014
- South of Adelaide
- 1,227
If all else fails I'll make my own hobs but I would rather buy them. Did you relieve the teeth on the hob? and if so how did you do it?
One of these would make it easy.
http://www.youtube.com/watch?v=pcOfChvoj40
12th Jun 2014, 09:16 PM #7Golden Member
- Jun 2004
- Kyabram. Vic
- 632
I believe that when gashing the teeth on home made hobs the face of the tooth is at circumference height which gives relief to the tooth.
Ken
12th Jun 2014, 09:51 PM #8Philomath in training
- 6,563
It was only a small hob cutting into plastic, so no relief was used. When the real one comes back from holidays I was going to harden it and then do a little precision angle grinder work. However, now I have a surface grinder and so could set the hob up parallel to the mag table and do it that way - a little more repeatable.
This is an end view of the practice cutter I made up. OD= 36mm. I wanted to get a couple of teeth in the cut at once so it has 12 teeth per rev which is about as many as I could comfortably fit. By moving my relieving cutter across a little I also got some positive rake on the teeth. The end faces are not all that wide (bit under 4mm), so relief would not be a difficult thing to do with a pass or two of a grinder.
MichaelLast edited by Michael G; 12th Jun 2014 at 10:35 PM. Reason: added pic
1st Oct 2019, 08:19 PM #9
Gears
Hi I have a qualos lathe and I need a new worm gear made for it. Would anyone be interested in making one? Would be cool if the newgear was made on a qualos gear hobb too. No pressure
4th Oct 2019, 07:30 PM #10Diamond Member
- Mar 2014
- South of Adelaide
- 1,227
wow cant believe i bought that 5 years ago. I still haven't used it, its oiled up under a cover in the corner of the shed. I can't buy collets so i will have to make them, and i need make a new arbor for the hob as 5/16" bore hobs are rarer than rocking horse poo.
QUALOS lathe
By morrisman in forum METALWORK GENERALReplies: 82Last Post: 11th Jun 2023, 08:11 PM -
Qualos drill chuck 1/16 -1/2
By woodfast in forum METALWORK GENERALReplies: 0Last Post: 9th Mar 2014, 12:07 PM -
Travelling steady for a B model Qualos
By Metmachmad in forum METALWORK GENERALReplies: 34Last Post: 2nd Sep 2011, 11:49 PM -
N.S.W. Gear Hobber Castings
By Swarfmaker1 in forum METALWORK - Machinery, Equipment, MARKETReplies: 3Last Post: 24th Jul 2011, 06:26 PM -
Newbie looking for some help with Qualos
By Metmachmad in forum METALWORK GENERALReplies: 8Last Post: 11th Aug 2010, 10:32 AM
