Results 46 to 60 of 71
9th Jun 2014, 10:18 AM #46
9th Jun 2014, 11:44 AM #47
How many insulating sleeves am I likely to find in total. I have counted 10 so far. Thats all I have found. 12?
There is one connection I have found so far. Where the arrow is, but behind the visible sleeve. It can only be seen with the use of a small mirror. I am now wishing I had an even smaller one.
9th Jun 2014, 01:02 PM #48Golden Member
- Sep 2008
- Riddells Creek, Vic.
- 838
Dean, you need to find the one with 3 wires, possibly 2 going into the sleeve from one end and 1 from the other end of the sleeve like this.
9th Jun 2014, 02:22 PM #49
Techo, I do understand that, but I cannot see what is invisible. All of the windings are well inside the casing which limits sight angles, hence the wish for a smaller mirror.
I have made a mirror about 8mm x 10mm on a handle bent at about 45 deg. The mirror was cut from a HDD platter. This is a vast improvement but is still a bit big in places (the raised parts on inside of casting). However this is as small as I think is usable for my older eyes.
I am using a headband magnifier.
I have carefully examined the entire end of the windings. My position has not changed. 10(?) insulating sleeves plus the 3 I have already released, which I did not point out before. One connection with 3 wires as pointed out in the picture.
The only options I have now are to either press out the stator after removing the welds, or release the sleeves from the varnish to enable a better view behind.
I am going to do something else for a while and ponder this. Maybe I should look at a different motor for a change. Is the big old clunker from the Nuttall likely to be a possble contender or should I forget it. It is 3Hp and rather bulky. It would suit the era of the shaper quite nicely.
9th Jun 2014, 03:40 PM #50Most Valued Member
9th Jun 2014, 07:14 PM #51
OK Dean, if you can't see the one with three wires going in, release the one in front of it and carefully move it out of the way. Once you find the one with three wires going in, release that oo and slice the sleeve open to confirm the connection inside. You'll just go "Eureka!" and get on with cutting it and splicing new cables to them....
Cheers, Joe
9th Jun 2014, 09:11 PM #52
Ok. For some reason I was thinking I need to find 3 connections. I just visualised one of the many diagrams I found or received while trying to work out the lathe motor connection, and realised it was 3 wires to one connection. Sigh.
What is the latest thoughts on what is needed to bring out these wires. According to what I was told by the local motor rewinder, almost any cord is suitable. I do need some spray to stick it all back down again. That leaves the wire and spagetti. As the motor does not need to be baked, will ordinary wire work, as well as normal spagetti?
I retreived the other 2 motors mentioned previously, today. There is a 1Hp Wye connection made by Pope and a 3Hp Delta connection made by Crompton Parkinson. At least I know what I am dealing with. The drill motor plate says virtually nothing useful.
9th Jun 2014, 09:20 PM #53
Use a two part epoxy (like Araldite) to stick it all down - not spray. I'd use silicone insulated wires and fireglass spagetti tuing (all better for a bit of motor heat in the longer term.
Cheers, Joe
9th Jun 2014, 10:21 PM #54
Ok Joe.
One thing I found interesting is the material used to hold the windings in the slot.
This picture is just a selection cut from an existing picture so will not be all that good. It looks to me like cane. The type of cane used to make furniture etc. I scraped the end of a bit with my pocket knife today and it acted like cane. As you can see it looks very porous. Considering the age of this motor I don't think it is some high tech low density polymer. A low tech polymer? Intriguing.
9th Jun 2014, 11:50 PM #55
Hi Dean,
The 2hp motor on my Hercus drill press has similar materials. Only it is definitely a timber "dowel" not cane. I would have thought with the heat shrinkage might be an issue but it seems not.
5th Jul 2014, 09:20 AM #56
Some time back, in another thread, I said I was going to get a Megger. I did finally get around to ordering it and it turned up yesterday. Another item that arrived was a replacement hand held tacho. I bought one to help with checking speeds on the lathe, using the VFD. It worked for a few days then the laser stopped working. The seller offered to send a replacement. The problem was that a couple of days ago I checked all my EBay purchases to see what was going on. (I have 2 hemostats that are about 8 weeks overdue from China. $2.86 down the drain.) I found the message from the Tacho seller offering a replacement, but I could not find my reply. Oops. Immediate reply sent with appologies. A couple of days later and it arrived. Last night, when unpacking I got them mixed up. The one with the battery is the old one! But it works? Swap batteries and this one also works. A comparison of the two (you would have to do this wouldn't you?) showed them to be virtually identical just by eye. A picture would freeze the action. So they are both showing the same result. Whether this is an accurate result?
Anyway, the real reason for this post is that the Megger came with a reasonable looking set of instructions, but only in Chinese.
Could someone please give me a quick rundown on it? Normally I would play, but in this case I am heeding the warnings given. I have not even unwrapped the leads yet.
5th Jul 2014, 11:20 AM #57Most Valued Member
- 4,258
I have no idea why they have two sets voltage scales...normally they only have one set of voltage scales ie 240, 500, 1000 with a couple low resistance scales.
I would play with it...dont use it on yourself...they dont hurt....... much...not too much trust me
As for testing insulation resistance i have used a cindered match or spittle wiped across a piece of timber..it is not an accuracy test by anymeans, but is indictative of if the thing is working or not....and of course dont use it on anything electronic.
a dead short ( connetct leads together together) will give a reading...apart should not show, and spittle or cindered match some where in between
the infinity symbol says all is ok at 240 and 500....generally one does not need to use 1000V...I use 500v for everything ie on 240v and 500v motors
any thing less than say 10mohm may need further checking or anylisis with below 1 not acceptable...above 10 everyhting should be ok
( i think I have that right)...I use an analogue meggar and have become accustomed to just reading the location of the needle on the scale and dont actually notice the reading)
5th Jul 2014, 03:31 PM #58
Thanks Eskimo. I will have a play. Re the second scale, I wondered whether the ability to read Chinese would be of assistance here (Joe, another trip to the uni.) or if it is just for people who are dyslexic. Can Google translate Chinese characters from a picture? I guess you would have to provide the actual symbols. Gotta go. Got the shaper outside the shed hanging in the breeze and it could rain.
5th Jul 2014, 03:56 PM #59
Strange looking dial setup... I did a quick search and found an chinglish manual
ftp://[email protected]:Uzu%40!nwtu...09%20D6310.doc
No idea why they would put two identical ranges on the same switch.... maybe for left and right handed operators?
PS... As eskimo says they don't hurt ....much...
5th Jul 2014, 07:55 PM #60
Any worse than stepping over an electric fence?
Thanks for the link Ray.
Hmm. Clear as mud. Maybe its me. First time remember. I'm a Megger Virgin
4.L (LINE) input terminal (connected to line terminal of the to-be-tested object).
5.G input terminal: shielded terminal of the insulating resistance.
6.E (EARTH) input terminal (connected to EARTH terminal of the o-be-tested object)
The other 2 are connected to each end of the windings, so "G input terminal: shielded terminal of the insulating resistance." is the star point yes/no? And in order that each winding is checked seperately, the star point should be seperated first?
I could have researched this myself.
It was starting to rain when I went back out with my coffee which was the main reason I came inside. Shaper is safe and the skates got another workout. I have thought of an idea for using skates. Thick neoprene on top so all the skates follow the machine.
I am cleaning off the top of one of my benches so I will have a decent place to work on this motor instead of a little card table with a missing leg locking strap. Too many jobs and too little time.
Bringing an old Robot back to life - Surface Grinder.
By LexD in forum METALWORK GENERALReplies: 68Last Post: 30th Jan 2015, 05:58 PM
