Results 31 to 45 of 63
Thread: VFD Circuit Diagram Question
18th May 2014, 12:59 AM #31
Stuart et al.
I bought my $50 one from a TaoBao seller directly. Very tricky business. I wouldn't recommend it to less than VERY patient people - unless you can read and write Chinese (Han).
However, if you search on Alibabexpress.com and you have an account there, you turn up many interesting things, e.g.:
http://www.aliexpress.com/item/Simpl...590257750.html same as what I got,
http://www.aliexpress.com/item/VFD-f...652037921.html or even
http://www.aliexpress.com/item/Taian...605956419.html
Just because what you are looking for isn't there today doesn't mean it won't be tomorrow.....Cheers, Joe
18th May 2014, 01:56 AM #32
18th May 2014, 02:23 AM #33
Thanks Ray. Yes, I tend to be pretty cautious - with my credit card detail in particular. I haven't paid by card on Alibaba or TaoBao ever.
Cheers, Joe
18th May 2014, 11:41 AM #34
This morning I played with having a separate E Stop command. I got it to work. A number of hints have been made such as a NO switch.
Here is my circuit. I think it covers everything. I now have a Stop switch with ramp down and an E Stop switch with coasting stop. As Ueee mentioned, I need a coasting stop for the brake pedal. I had a look this morning and found the change gear door cutout switch was connected NO. I have not looked further yet.
18th May 2014, 11:54 AM #35Cba
- Aug 2007
- 68
- 1,410
E-stops should always be NC, to ensure that a broken cable (or a loose connector or a bad crimp etc) result in the e-stop being activated. This forces the user to investigate and fix the fault before using the machine.
With an NO e-stop, you could be working for years with a non operational e-stop and NOT knowing it. The day you need the e-stop because the chuck is winding-in your tie, it is too late to find out it is broken.
18th May 2014, 12:24 PM #36Most Valued Member
This is the reason I dont use the E/stop circuits. Its also why my "normal off"(foot pedal brake) is the E/stop(as such) as thats the one I'll going to go for when it hits the fan.
Joe....I havent given it a lot of thought but re your braking stop/ coasting stop issues. How about swapping the e/stop and normal stop. E/stop(NO) normal operation with coasting stop. Normal stop (NC) for emg stop with braking? As I said I've given 0 thought to how you'd go wiring this up as I dont know how to "reset" the VSD after E/stop. Though I'd still be using the normal stop(which is the e/stop in this case) for normal operations for the above reason.
As for brakes. The rotor for my lathe brake is just bolted to the motor pulley, you dont need much of a brake really(depending on the size of the machine of course).
18th May 2014, 04:02 PM #37
Agreed, but it has been discussed already in Joe's thread. That is the way SPL is set up on these VFD's. I have the momentary brake pedal cutout switch connected to E/Stop and has been mentioned, this is probably the one that will be used for nearly all stops which will provide constant testing. There is still the problem with the tie wrapping itself around the chuck when the wiring has just failed, but I don't even possess a tie so I don't see much risk there.
18th May 2014, 04:28 PM #38Most Valued Member
18th May 2014, 04:38 PM #39
This is a very informative discussion. Just for the record, resetting the VFD after any error is just a matter of pushing the Stop button on the touch panel. It stays active even when all other controls are external. Although there is a parameter to disable that too....
JoeCheers, Joe
18th May 2014, 04:43 PM #40
I will see whats involved in changing my mill panel to separate the 'normal' stop from the E-stop. Apart from an extra wire.... which I don't have....
JoeCheers, Joe
18th May 2014, 05:44 PM #41
Dean et al.
So this should work for me? Haven't tried it yet...
Edit: I've got myself confused too!
Now corrected button assignmets and labled their use.
PDs remain and were correct.
Note there is no button associated with PD46/Rst/D3Cheers, Joe
18th May 2014, 06:28 PM #42Most Valued Member
Hi Joe,
So the NC switch it your E/stop?
After you do a "normal stop"(closing Spl)*. Dont you then need to open Rst before you can restart? Would be painful to have to press the E/stop(DCM NC) button to reset the VSD before closing For or Rev to restart.
*damn this is confusing when you are using E/stop and normal and normal as E/stop lol
18th May 2014, 07:32 PM #43
18th May 2014, 08:19 PM #44Most Valued Member
Hi Dean,
Thats right. I dont use the NO E/stop function on the VSD. The e/stop button is just another stop button.
There maybe a little confusion. My lathe doesnt have a VSD(I was just talking about the brake and e/stop set-up). My Mill has VSD, as far as the VSD goes there is no difference between the mills stop button and E/stop button.
18th May 2014, 09:00 PM #45
This is how mine would look with the addition of the jog functions.
Note the correction for Jog REV.
I appears to me that Pd046 should be set to 13 and Pd049 set to 04.
I am not up to date on the ramp up and down aspects yet, but as DCM is set to ramp down via another setting as I read it, it would need to be set so there was no ramp down at all so the brake is not fighting with the motor, as Ueee mentioned.
I have no idea whether a ramp down value can be applied to SPL. If not it means that both stops will have no ramp down, so you may as well use DCM for all stops and set ramp down to zero. I could easily be wrong. Just my understanding at this point.
Joe are you planning on using a latching switch on DCM?
Hi Joe,
motor wiring diagram
By .RC. in forum METALWORK GENERALReplies: 2Last Post: 12th Jul 2010, 07:37 PM
