Results 1 to 15 of 19
Thread: lathe levelling
13th May 2014, 10:02 PM #1
lathe levelling
I am about to open a can of worm with this topic
I have been turning between centres ( using the 3 jaw chuck and turned centre method ) , I am trying to achieve a decent straight cut over approx. 8" lenght . I firstly levelled the Sheraton bed with my U beaut brand new German machinists level , by adjusting the feet on the floor . Then, by taking trial cuts and moving the tailstock over a tiny tad, I tried my best , but this method has proved to be too much trial and error ! By the way this lathe is worn , it isn't new by any standards . Anyway tapping the tailstock over isn't precise enough - because its too easy to tap it too far or too little and for some reason I dont get decent repeatability with this method - the trial cuts are all over the place . So, I resorted to adjusting the 4 adjusting screws under each corner of the bed mounts - these are bed height adjusting screws within a lock down bolt . By moving two screws , diagonally opposed , I seem to have achieved a good result . The bed is still flat and the trial cuts are .0005" over the 8" .
So by twisting each corner of the bed , it seems to have done the trick ? Mike
13th May 2014, 11:01 PM #2Most Valued Member
You know this isnt RDM right?
What is this "tapping" of which you speak? Don't you have a dial gauge or DTI?
Isnt there two bolts you can work against each other to move the tailstock accurately?
Bed wear shouldn't be an issue.Turning between centers shouldn't need bed twisting, you should be able to do that with the tailstock.
You've now aligned the bed to the tailstock... not the other way around.
But.... if it got the job done.......
13th May 2014, 11:25 PM #3
tailstock
Hi Stuart
Yes the tailstock has 2 tiny screws each side , but these don't have enough force to move the tailstock across , it's far too tight . All they seem to do is lock the tailstock in position.
It's weird , but for some reason - when the 4 bed adjusting screws are all taken out of the equation - with no twisting - I cannot get any repeatability with my trial cuts , its only when the 2 diag. opposed bed screws are tensioned up, that all seems fine and the repeatability is good . Mike
13th May 2014, 11:28 PM #4
Hi Mike,
You may find now that if you try to turn a different length between centers it may not cut straight. Stu is right, use the 2 bolts to "torque" the t/s into alignment. With a dial on the t/s it is fairly easy to move the t/s half the dia difference the lathe has cut.
13th May 2014, 11:34 PM #5
14th May 2014, 12:49 AM #6
WRT the t/s not moving with the screws, i find you need to loosen the bed lock off a little and it will move more easily. A dial monitoring the movement means it is hard to go too far. You also need to be sure of how the screws work. On the antrac the screws are threaded into the top half of the T/S (they are really long grub screws) and just push on a block on the bottom half. The other lathes all have the screws threaded into the bottom half of the T/S. When i first went to adjust the Antrac i had no idea what was going on, i actually had to pull the T/S apart to see just how it went together.
One other thing though, with the lathes you own, why are you trying to do such precise work on the lightest and least rigid?
14th May 2014, 12:54 AM #7Most Valued Member
14th May 2014, 08:25 AM #8Distracted Member
- May 2010
- Lower Lakes SA
- 58
- 2,607
14th May 2014, 10:38 AM #9Distracted Member
- May 2010
- Lower Lakes SA
- 58
- 2,607
Or it could be the opposite. If you are right about the bed being straight when relaxed, maybe the saddle is rocking and when you put a twist in, it stabilises.
It's hard to understand from what you've written.
14th May 2014, 11:54 AM #10
LATHES
Yes , its just my backwards methods, doing it the hard way I am trying to tweak the Sheraton to a good accurate standard , by doing this I hopefully will learn about the ins and outs of lathes . Sometimes an anomaly comes along that doesnt add up . Its all part of the mysteries of machining . Mike
14th May 2014, 11:57 AM #11
14th May 2014, 12:50 PM #12
u toob again
This guy is using shims, but its basically what I am doing
http://www.youtube.com/watch?v=Dvs5YiDl_90
14th May 2014, 02:41 PM #13Most Valued Member
14th May 2014, 07:20 PM #14
[QUOTE=Stustoys;1774337].....leveling a lathe shouldnt have anything to do with turning between centers.....
Ok , I must have lathe theory the wrong way around. From what you guys are writing, It seems that the only reason for turning a taper between centres is because the tailstock is out of alignment In other words there are no other reasons at all
It could be, the bed is worn towards the headstock, causing the tool traverse to lower . Mike
14th May 2014, 08:17 PM #15Most Valued Member
Lathe Levelling - A Different Tack
By Anorak Bob in forum METALWORK GENERALReplies: 12Last Post: 22nd Jul 2012, 12:04 PM -
Lathe Levelling
By Anorak Bob in forum METALWORK GENERALReplies: 112Last Post: 12th Jul 2012, 01:04 AM -
lathe levelling
By YarrD in forum METALWORK GENERALReplies: 4Last Post: 26th Oct 2011, 10:58 PM
