Results 16 to 23 of 23
6th May 2014, 08:32 PM #16Most Valued Member
- 4,887
That could well and truly be correct for the thread diameter you worked on but it has changed.
Mine could be a bit tight
6th May 2014, 08:34 PM #17Most Valued Member
- Sep 2011
- Ballarat
- 3,103
6th May 2014, 08:58 PM #181915 17"x50" LeBlond heavy duty Lathe, 24" Queen city shaper, 1970's G Vernier FV.3.TO Universal Mill, 1958 Blohm HFS 6 surface grinder, 1942 Rivett 715 Lathe, 14"x40" Antrac Lathe, Startrite H225 Bandsaw, 1949 Hercus Camelback Drill press, 1947 Holbrook C10 Lathe.
6th May 2014, 10:39 PM #19Most Valued Member
- Sep 2011
- Ballarat
- 3,103
Thanks Ew,
Now, to cancel one senior moment...
8th May 2014, 03:41 AM #20Most Valued Member
- Oct 2010
- melbourne, laverton
- 1,910
uns thread
thanks pipeclay,ew ,phil,lex and every one.
ya i messed up the size its 4.5 not 2.5.
as far as class of fit if im going to use this as a thread gauge
for up coming jobs what class would be best to make this?
aaron
8th May 2014, 06:06 AM #21Most Valued Member
- Sep 2011
- Ballarat
- 3,103
Hi Aaron,
not sure if I am too late or not but,
basic dimensions for minor diameter of an internal 4 1/2" 6 TPI thread is 4.3196".
Phil
8th May 2014, 09:48 AM #22Most Valued Member
- Oct 2010
- 1,910
never to late
may of been phil but i didn't have any thing to measure internally last night.
plus my out side mic the right size is not here either.
so thanks.
how do i figure out the minor dia or doc.
aaron
8th May 2014, 11:13 AM #23Golden Member
- Sep 2008
- Riddells Creek, Vic.
- 831
Aaron, your bored hole IS the minor diameter, the theoretical Major diameter is simply the nominal size, in this case 4.5". So the depth of cut will be 4.500" minus 4.320" to 4.3396" divided by 2.
Regards, Lex.
Cutting a 1 1/2 Inch 8 TPI - UN thread
By 19brendan81 in forum METALWORK GENERALReplies: 11Last Post: 9th Jun 2010, 03:40 PM
