Results 1 to 15 of 35
Thread: Starting a Stent tool grinder.
29th Apr 2014, 09:45 AM #1future machinist
- Mar 2008
- nowra
- 1,598
Around two years ago Michael G sent me these stent casting, he had already machined the dovetails. So last weekend we finally made a start on it, I have machined most of the spindle and used my little atlas shaper for the first time in vein to machine the spindle casting.
Andre
29th Apr 2014, 10:31 AM #2
29th Apr 2014, 10:50 AM #3
Hi Andre,
Good to see some progress, but no 40tpi threads
Its interesting to see you get the pattern of diagonal lines in the finish from the shaper too. I guess its the bull gear teeth leaving their mark?
29th Apr 2014, 11:02 PM #4future machinist
- Mar 2008
- nowra
- 1,598
Yeah I substituted the 7/16" 40 tpi model engineers for an m12 fine pitch it should work. As for the shaper I don't have any idea
Andre
26th Jan 2015, 11:50 PM #5future machinist
- Mar 2008
- nowra
- 1,598
well I pulled the project out of hiatuses, As I have the CVA almost wired up I had a go at cutting the tee slots for the table.They came out okay put I'm not 100% happy but it will do. They are 10 mm tee slots I roughed them out with a nice new 6mm cutter and hacked away with a blunt 10 mm till it was done learnt a lesson in climb vs conventional milling today
Andre
27th Jan 2015, 12:02 AM #6Most Valued Member
- 4,890
Where was the climb milling in the tee slot cutting?
27th Jan 2015, 06:33 AM #7future machinist
- Mar 2008
- nowra
- 1,598
When cutting the initial slot I climb-milled as that didnt work out too well.
Andre
27th Jan 2015, 08:15 AM #8Most Valued Member
- 4,890
Still cant see where the climb milling comes into it when cutting a slot.
27th Jan 2015, 09:03 AM #9Most Valued Member
27th Jan 2015, 09:16 AM #10future machinist
- Mar 2008
- nowra
- 1,598
Well I don't know boys I might have my terms wrong but when I fed the tee slot cutter in it pulled in and shook the table going one direction but not going the other direction so may be the mill.
Andre
27th Jan 2015, 12:10 PM #11Most Valued Member
- 4,890
I would think that there is something either not fitting correctly or your gib may be to loose or you didn't remove backlash.
27th Jan 2015, 12:12 PM #12Most Valued Member
- 4,890
27th Jan 2015, 01:00 PM #13future machinist
- Mar 2008
- nowra
- 1,598
Well now you say this Pipeclay it was most likely was me not taking out the backlash as the problems only ensued in the first 1inch or two of cutting. I only thought climb milling as I was traversing in the direction you would go if using an endmill climbmilling. Does the direction of milling make no difference when cutting with both sides of a cutter ?
Andre
27th Jan 2015, 01:33 PM #14Most Valued Member
- 4,890
Makes no difference when cutting a slot as one side would be conventional and the opposite climbing.
27th Jan 2015, 01:52 PM #15future machinist
- Mar 2008
- nowra
- 1,598
Cheers pipeclay a wealth of knowledge as usual.
Andre
Tool and Cutter grinder
By 4-6-4 in forum METALWORK GENERALReplies: 2Last Post: 12th Oct 2011, 11:40 PM -
Tool post grinder
By morrisman in forum METALWORK GENERALReplies: 10Last Post: 23rd Jul 2011, 08:44 PM -
Tool & Cutter Grinder
By graemet in forum METALWORK GENERALReplies: 14Last Post: 20th Nov 2009, 08:27 AM
