Results 1 to 9 of 9
Thread: re QCTP's
    Sep 2008
    texas, queensland
    248
    Default re QCTP's
    question for the learned , i have a cq6230 lathe ( or al400 equiv ) it has a 12" swing i would like to get a qctp for it from what i can see i can use either an AXA or a BXA with the axa it is on its limits cos it does up to 12 " swing , the bxa does 10 to 15" swing so what would be the better option get the axa or would there be an advantage having the bxa . never having used one at all i cant tell , would the bxa be a lot bulkier ( is that a word ) and or would the axa flex more ????.
    thanks
    johno
    'If the enemy is in range, so are you.'
    Jun 2007
    sydney ( st marys )
    62
    4,735
    Not sure over the pros and cons of each,but would think if one only goes as far as 12" you would be silly not to go for the one that does 15" max.
    If one might be flimsy going to 12" max then the other would be just as flimsy going to 15" max.
    Just buy the BXA.
    Ueee's Avatar
    Dec 2011
    Canberra
    37
    4,515
    Hi Johno,
    The main thing to check is the height from the top of the compound to the center. I think a BXA needs at least 30mm if you use 16mm tools. The aloris site has all the You will not find the BXA too bulky, i think they are a good size, and rigid enough to take 3mm DOC's with negative rake carbide on one of my machines.
    Having said that i think i am going to get a Multifix clone from create tools for the C10 http://www.createtool.com/index.asp Something else to think about, but not as cheap as the Aloris type.
    Ew
    Dec 2011
    Sydney
    453
    Johno,
    It's not only the swing that determines the best size, the height from the top of the compound slide to the spindle axis can be relevant. Your preferred size of tool shank comes in here because if the compound-to spindle axis height is limited you might have trouble with your preferred tool shank size leaving the cutting edge above centre.
    BXA tool holders accommodate larger tooling (that's good) but have more metal under the tool shank than AXA, so the lowest position of a given cutting tool is higher than with an AXA system.
    Bill
    Edit - typing too slow!
    Aug 2012
    Australia
    645
    I recently had to decide the same thing, AXA vs BXA for my AL960b. I wanted to do the deepest cuts possible for my machine and figured the limitation of 12mm tools with the AXA was the deciding factor. I heard that BXA could be bulky, but that was not the case for me. My BXA is excellent. Perfect size, does not get in the way at all, can easily see the work and takes both 12 and 16mm tools. Glad I went with the BXA!
    PS if you want to get good quality but do not have the budget for Aloris, then go through Use-Enco in the US. They have Phase II which are reputed to be the best of the Chinese tool posts. Mine is excellent and I am glad I purchased it.
    Sep 2008
    texas, queensland
    248
    just did a measure of the top of compound to centre of spindle and it is 28.2mm so ill call it 28mm . i use mainly 12mm tooling or smaller sometimes with a multitude of pesky shims .i take smaller cuts mainly 40 or 50 thou would be about as deep as i cut most of the time .
    johno
    Jun 2007
    sydney ( st marys )
    62
    4,735
    If that's the case spend the money on HSS and stay with what you have.
    Aug 2007
    66
    1,410
    Quote Originally Posted by texx View Post
    johno
    Sounds like you have made up your mind for an American type toolpost. If much of what you do is small and intricate jobs, you are best served with the smaller AXA. The larger BXA can get in the way and hides what you need to see.
    Apr 2009
    Kingswood
    857
    Hi Johno,
    Before committing to a particular QCTP, check the ability to mount the tool of choice and maintain clearances from your rotating centre with a typical work diameter.
    You will quickly find that even HSS needs to be mounted in a holder just to get clearances.
    John.
  1. Qctp
    By jack620 in forum METALWORK GENERAL
    Last Post: 13th Apr 2013, 11:35 AM
  2. QCTP for AL-33X
    By Sterob in forum METALWORK GENERAL
    Last Post: 22nd Jun 2010, 12:42 AM
  3. New QCTP - which one?
    By markjaffa in forum METALWORK GENERAL
    Last Post: 16th Nov 2009, 05:04 AM
  4. Right QCTP for me?
    By ElDubya in forum METALWORK GENERAL
    Last Post: 12th Nov 2008, 11:51 PM
  5. H&f Qctp
    By Beerbotboffin in forum METALWORK GENERAL
    Last Post: 7th Nov 2007, 05:36 PM
