Results 61 to 63 of 63
13th Jun 2014, 09:56 AM #61Most Valued Member
- Australia east coast
- 2,713
I just reverse my Chipmaster 3 phase motor - the lever is on the headstock. If I don't want to be that brutal I use the clutch lever, which is on the headstock....
After getting 2 lathes with clutched spindles, I hate using ones without. The Monarch CY has a clutch too.
PDW
14th Jun 2014, 10:39 AM #62
Thats where i like the foot brake. At slower speeds you can stop the spindle dead, and you still have both hands on the controls.
I often remove the need for precision stopping when threading anyway. Turn your tool upside down or use it in a rear mount holder and thread in reverse. You can thread at high speeds with no risk of crashing into a shoulder or blind hole. You don't even need a runout groove to start in, just plunge the tool in and engage the half nuts.
14th Jun 2014, 02:25 PM #63Most Valued Member
- 2,713
Huanyang VFD front panel pot
By RayG in forum METALWORK GENERALReplies: 72Last Post: 20th Feb 2013, 01:27 PM
