Results 1 to 5 of 5
    Jul 2009
    Sydney
    45
    42
    Default Taper Pins and taper pin reamers
    I have a little job where I need to retain a sleeved fitting. It was previously retained with taper pins. I have not used them before. I've fitted the sleeve and I assume that I need to cross drill to the minor diameter of the taper pin, then ream the taper, then install the pin.
    The pins I'll need are about 10mm long and 3 mm diameter. Does the pin come as stock lengths so you cut off the fitting section to install, or does it come as short sections? And how does the number system work with regards to diameter?
    Have I got it right how you use them, ie. drill to minor diameter, ream, install taper pin that fits (cut from stock)?
    I appreciate the help.
    Ueee's Avatar
    Dec 2011
    Canberra
    40
    4,515
    Hi,
    Here is a link that gives you the sizes for imperial reamers. http://stanlok.com/Taper_Pin_Pages/t...n_reamers.html These are tapered at 1:48. Metric pins are 1:50. I have always just turned new pins to suit, normally from silver steel, but i know you can buy them too.
    As far as drilling and reaming goes, how you describe it is how i do it.
    Ewan
    May 2010
    Lower Lakes SA
    58
    2,607
    Jul 2009
    Sydney
    45
    42
    Thanks for the replies gent's, I think I should be able to get it done right now.
    Appreciated.
    6,475
    Hi tbonesmith
    Have you considered these
    http://www.smallparts.com.au/store/c...ies/Pins+Roll/
    Simply drill the right size hole and press them into place.
  1. Roll pins vs taper pins
    By bob ward in forum METALWORK GENERAL
    Last Post: 9th May 2014, 10:10 AM
  2. Taper Pin Reamers
    Last Post: 8th Apr 2012, 12:46 AM
  3. Threaded Taper Pins
    Last Post: 26th Jul 2010, 02:43 PM
  4. Metric vs Imperial taper pins
    By Metalman in forum METALWORK GENERAL
    Last Post: 17th Oct 2009, 11:10 AM
