Results 16 to 30 of 30
Thread: Bearings for Skates
15th Apr 2014, 05:01 PM #16
Thanks Ewan and PDW. A couple more ideas to ponder.
15th Apr 2014, 06:17 PM #17
Hi Dean,
What about these? http://www.vxb.com/page/bearings/PRO...200-2RSBearing
I remember someone posting about a method of moving a machine in a tight spot using blocks of ice. The advantage is that it's self lowering when you get it in place..
17th Apr 2014, 10:57 PM #18.
- 6,459
I just saw that Ray had replied to this thread and thought it an opportune time to post these photos. There are some serious looking rollers supporting this nice FP3L. Bit bigger than the Gardiner's but the correct colour.
BT
17th Apr 2014, 11:42 PM #19Distracted Member
- May 2010
- Lower Lakes SA
- 58
- 2,607
I used a set of these casters for a purpose built dolly under (bolted to) my tailstock http://www.ebay.com.au/itm/4-4-Indus...item3a8bd69f81 and a pallet jack under the headstock.
18th Apr 2014, 06:48 AM #20
18th Apr 2014, 08:45 AM #21Golden Member
- Apr 2009
- Kingswood
- 930
Dean,
Attached are a couple of photos of a trolley I made for my grinder as I don't have a home for it yet.
Rated for 900 kg, width to suit all the machines within that weight, and fitted with extendable length runners.
Welded pads suit the grinder, other pads will be welded on as needed.
Floor jacking pads remove the weight from the castors.
Needs some strengthening gussets before its next use.
Breaks down into 4 pieces for easy transport and storage.
John
18th Apr 2014, 08:42 PM #22
19th Apr 2014, 01:47 AM #23
19th Apr 2014, 01:02 PM #24.
- 6,459
eBay.de Ray. http://www.ebay.de/itm/Deckel-FP3L-F...item3a8f06b670
I think the differences were a bigger donk, the standard FP2 had a 3 horse motor , the FP3 and 3L, 4hp and the 3 had more Y travel with 300mm compared to the 200 of the 2. This info was gleaned from a 1975 KF copy milling machine catalogue I have. It features a brief summary of the other machines Deckel manufactured at that time.The FP2L was not listed.
BT
21st Apr 2014, 01:23 PM #25Banned
- Jul 2011
- Melbourne Australia
- 1,376
G'day Bob.
Those would be GKS Perfekt dollies. They are the Rolls Royce of machinery skates. Their Robot and a set of their machine jacks are on my to-do list when my Tattslotto comes in.
http://gksweb.com/dollies/transport-dollies/
There's a mob called Team Solutions, that sell a Chinese kind of copy of them. I bought a set of there 6T, they seem to be fine. I priced this 4T, 3 point set last year. It was only in the $300 range
http://teamsystems.net.au/skates/750....html#myAnchor
They also sell just the wheels, that might be an option for the roll your own crowd.
http://teamsystems.net.au/14-pallet-...heels#myAnchor
Regards Phil.
(On Edit) Also found these on Oz Ebay. http://www.ebay.com.au/itm/2x-Polyur...-/281274935273
http://www.ebay.com.au/itm/2x-Solid-...-/281274936342
At $25 bucks each delivered, and including the bearings, you would be hard pressed to make them for that.
21st Apr 2014, 02:49 PM #26Most Valued Member
- Australia east coast
- 2,713
Dead right - I can see an order going their way real soon now. Even though I've bought some bushings I still have to machine out the steel rollers to fit them - I drilled an undersize hole before welding the slugs into some short pieces of Sched 80 pipe so I could finish bore to size. It's all time and I have little to spare for projects when $200 makes the issue go away....
Thanks for that posting, I appreciate it.
PDW
21st Apr 2014, 07:50 PM #27
The search is over. I found that we already have some skates, we bought some years ago.
21st Apr 2014, 08:19 PM #28Most Valued Member
So why would I choose polyurethane over nylon or V V?
22nd Apr 2014, 03:07 PM #29Banned
- Jul 2011
- 1,376
22nd Apr 2014, 03:13 PM #30Most Valued Member
Bearings
By neddyo in forum THE HERCUS AREAReplies: 5Last Post: 19th Feb 2014, 10:02 PM -
Where to buy Bearings
By welder in forum METALWORK GENERALReplies: 22Last Post: 5th May 2013, 11:43 AM
