Page 2 of 2 FirstFirst 12
Results 16 to 21 of 21
  1. #16
    7,188
    BJ's got it, but just in case.
  2. #17
    Jul 2006
    Athelstone, SA 5076
    4,258
    WCD's would be my preference
    with the one from Bobl i think the two locking levers(for the sake of a better word...cos i dont know what else to call em) shown with movement arrows in last pic may become permanently distorted and bind ...the rotating nut locking mechanism will always be tightened to a differing torque accelerating the eventual binding?
  3. #18
    Aug 2010
    Horsham Victoria
    113
    Ok thanks guys
    I was not sure if the white in your pic was material or a void.
    Crystal clear now.
    Well this looks a very viable proposition to me.
    I thank you all for your input. I will let you know of my progress. As this is a wood lathe I may make up a model from timber first though drilling the 44.5 mm holes nice and true, straight and parallel may be an issue.
    Dave the turning cowboy
    turning wood into art
  4. #19
    7,188
    Manufacture tolerance has to be good, but I've had a similar sort of locking mechanism to lock the wheels on my small Alaskan chain saw mill for the last 4 years without a problem.
    The trick with these locking mechanism is they need only a light touch to provide massive clamping on the bars but this reduced amount of force may not be enough to lock the T-slot.
    A simple design with a zero chance of binding is this one.
    Easy to make too - just drill the holes through the metal block and then cut the block in half.
    I just realised the horizontal void doesn't go through the middle of the bars but I think you get the picture.
  5. #20
    Jul 2006
    Athelstone, SA 5076
    4,258
    that looks better
  6. #21
    Ueee's Avatar
    Dec 2011
    Canberra
    39
    4,515
    I think It could be made even simpler.
    Hey have you been looking in my head? It's not really my idea, but it was what I would suggest. The record bar bed lathes used a simplified version of it. Not only is it easy it gives equal clamping on the bed and t slotted part, unlike the wedges which would be tight long before the t slot part would be.
    Ew
