Results 16 to 27 of 27
9th Apr 2014, 12:32 AM #16Most Valued Member
- Australia east coast
- 2,713
I'd make a pattern and get a casting done. But this wouldn't be cheap which is why, if you have no money that you're willing to spend, it's pointless saying in detail how to do it. Especially if you're going to put it on a wood lathe bed comprised of a couple of round bars. I mean, what's the point? It's going to lack both accuracy *and* rigidity.
As for steel, I'd prefer a Cast iron bottom shoe and a steel upper body if I had to go this way, but it comes back again to the fact that, if you want to make a TS for a metal lathe, you'd better have at least *some* clue about what you're trying to achieve.
Now if you want to make something that looks vaguely like a TS but aren't going to bother with minor details like having the bore on the centre line and parallel to the bed both vertically & horizontally to tolerances of say 0.0002" over 6", that's a different matter. But please don't call it a metal lathe tailstock, that's like describing something hacked out of a bit of railway iron with a cutting torch as an anvil.
Somewhere I have a book on making a wood lathe using all fabricated parts. It looked eminently do-able, including the tailstock. But it was not and never, ever could be considered as suitable for turning metal.
PDW
9th Apr 2014, 12:42 AM #17
Tail stock question - cast v's welded
I want accuarate. not sure how accurate I can get. It is a wood lathe but I would like to be able to use it on some steel too. The bed it two round tubes OD about 44.5mm
Im not happy with my NOVA 3000, it is poorly machined and not very accurate in my opinion, I think I can make this old lathe better than the NOVA
Dave the turning cowboy
turning wood into art
9th Apr 2014, 12:55 AM #18
You simply can't turn steel on a wood lathe. Spin maybe, but not turn. Your 44.5mm bar may as well be two lengths of cooked spaghetti, bar bed lathes will always lack rigidity due to their design. For turning steel you need lowers speeds, completely different toolpost etc, mass and rigidity.
As far as your T/S goes, welding one up would be easy, making the quill to suit and boring the T/S will be the fun parts. But its a wood lathe, if its out .010" it doesn't matter at all, the timber will move far more than that just from the heat imparted through turning.
9th Apr 2014, 04:06 AM #19Member: Blue and white apron brigade
9th Apr 2014, 09:20 AM #20
so a dedicated metal lathe could be an add to my repitwar down the track
9th Apr 2014, 09:53 AM #21Member: Blue and white apron brigade
9th Apr 2014, 10:06 AM #22Most Valued Member
- 4,258
9th Apr 2014, 10:08 AM #23Most Valued Member
- 4,258
9th Apr 2014, 11:00 AM #24Golden Member
- Mar 2009
- 54
- 825
G’day Dave,
For what it’s worth, people will line up all day long to tell you what’s not possible, to be frank, opinions are like bum holes, everyone’s got one and here’s mine.
If you really want to know what can and can’t be done you just need to have a crack and see what happens.
Can you use a wood lathe for turning metal? You bet you can, you just have to be realistic in what you do.
If you plan to take large depths of cut, seek sub thou of an inch accuracy or turn large heavy items then you really need a metal lathe.
If however you just want to put a point back on your damaged wood lathe centre, turn up an axle for a trolley or make a decorative knob for your latest creation then your wood lathe will be more than capable of the job, you will just have to be patient and take small cuts. Working in softer material like brass and aluminium will be easier but you can also work steel just as effectively.
I presume you are planning to use a graver tool on your woodturning rest because while devising and making a carriage for your wood lathe is no doubt possible, it’s probably not really worth it unless you want to prove you can.
EDIT: I see from your other thread that's exactly what you plan to do, two big thumbs up for having a crack.
As for yourtailstock, if you want quick, easy and effective, I would go with fabricating one.
If however you’re up for a challenge then you could have a crack at making a pattern and casting the body out of alloy, the type you can get from old mower bases and the like. You can do all of this yourself and if it all works out you could even take your pattern and get it cast in iron down the track and you will have learned a lot of additional skills you can use on your other projects.
Whichever option you go with I hope it all works out and good luck.
Greg.
9th Apr 2014, 11:54 AM #25
Thanks Greg,
Any metal turning would probably not about what you suggest, small and minimal.
I dont know what a graver tool is but sure I will find out in short while, It is great all the in put I am getting. What I have is on old shopsmith. It is probably more of a challenge than anything else. I want to show that it could have been a better machine.
It will be long term project no doubt as I fix one aspect at a time. There is no fabricated one that I know of that is not somewhat flimsy, that is why I want to redesign it. What they do have is a carriage slide that is used for the tool rest. what I may be able to do is source another one of these and modify a fabricated Tail Stock to bolt immediately to this. Probably better this than fabricate an entire tail stock as it gives me more latitude for adjustment. If I have three fixed holes, two for the carriage ways and one for the MT they have to be spot on in every direction first time round.
9th Apr 2014, 06:33 PM #26Most Valued Member
- Sep 2010
- Lebrina
- 1,915
Totally agree.
At no time was I talking a tailstock for a metal lathe. As far as I knew, we were only ever talking woodlathes.
For all the reasons you mention and more, making a metal lathe tailstock is a major undertaking, requiring superbly accurate machine work.
For all intents and purposes, the only real accuracy required of a wood lathe is in the runout of the headstock drive shaft and faceplate if fitted. All cutting/turning operations being hand guided make the finest accuracy standards totally redundant anyway. Copy lathes are a bit different kettle of fish, but they still work using a medium that swells and shrinks at will.
15th Apr 2014, 09:03 AM #27Most Valued Member
- 4,258
Tail stock trouble.
By cookie48 in forum METALWORK GENERALReplies: 10Last Post: 25th Apr 2012, 03:40 PM
