Results 1 to 12 of 12
30th Mar 2014, 11:10 PM #1Golden Member
- Nov 2010
- Gippsland Victoria
- 733
basic gas torch vocabulary for newbs
When I read the different metalwork books from the library, various home made tools are portrayed as relatively easy exercises.
You just go to the shed, shape up a bit of silver steel then heat to "straw" or "cherry red" then either quench in oil/water, cool in air then maybe reheat or chuck it in a tin full of sand in the oven when nobody is looking and hey presto you have a new home made gizmo. Precise instructions are usually given in the books.
As a starting exercise, I tried to heat up some metal with a little gas torch and there wasn't even the slightest hint of a colour change.
Suspect I have to get a much bigger flame.
My little gas torch screws directly into a tiny gas cylinder - easily held in one hand - what do I need to buy to get little bits of metal red hot ?
any good web sites or previous threads to get me started learning what I need to buy ? Am not sure of the right words to search for in google / ebay / gumtree etc
Bill
30th Mar 2014, 11:35 PM #2
Torch
Bill, If you can afford it, get a Bullfinch brazing torch ..... search through the posts on this forum for Bullfinch . Mike
31st Mar 2014, 02:40 AM #3Diamond Member
- Feb 2013
- Laidley, SE Qld
- 1,038
Bill, there are several ways of doing what you want and I'm sure all of those methods plus a few will be posted here shortly.
For small items, say heating the tip of a 10mm round, a Bernzomatic or similar from Bunnings works well. You can also buy a torch similar to the Bernzomatic torch that attaches to a standard bbq LPG gas bottle.
For larger items I use the oxy/lpg set, others will use oxy/aetylene.
For big stuff I use a homemade (made from waterpipe fittings) LPG torch.
31st Mar 2014, 08:29 AM #4Most Valued Member
- 4,255
2nd Apr 2014, 12:55 AM #5Diamond Member
- Feb 2013
- Laidley, SE Qld
- 1,038
No drawings but I can do a photo and a few words of description. None of the dimensions are super critical, the whole thing is just an oversize bunsen burner.
300mm long 1/2" water pipe
At the RH end is a socket tapered on the inside
At the LH end is a 1/2" x 1 1/2" socket
LPG nozzle is a .6mm MIG tip (use a .8mm tip for 3/4" pipe and a .9mm tip for 1" pipe)
You need air intake holes with a total area twice that of the piece of pipe and a choke so you can fine tune the airflow.
The nose of the MIG nozzle needs to be 1/2" back from the start of the 1/2" pipe.
2nd Apr 2014, 09:57 AM #6Pink 10EE owner
- 6,216
I think the nomenclature is pretty easy...
We have smelly stuff tap.
Hot bit
Sparky thing for lighting it...Gold, the colour of choice for the discerning person.
2nd Apr 2014, 11:27 AM #7Most Valued Member
- 4,255
2nd Apr 2014, 02:16 PM #8Diamond Member
- N.W.Tasmania
- 1,407
Bob, I wonder if you could just clarify, does the gas valve and jet assy screw into the reducing socket, through a bulkhead style fitting - like some 10mm plate of appropriate diameter, and threaded 1 1/2" bsp?
Secondly where are the air inlet holes, are they in the bulkhead plate or more likely perhaps, through the side of the reducing socket, under what I presume to be two annular rings, the inner being fastened by the SHCSs to the reducer, and the outer ring being a close sliding fit over the inner, and slotted to allow the air to be throttled as it passes through to the holes underneath in the reducing socket?
Finally what is the purpose of the socket on the hot end? Thanks,
Rob.
2nd Apr 2014, 06:10 PM #9Cba
- Aug 2007
- 68
- 1,410
Bill, it is soon getting cold outside. We run two slow combustion heaters to keep our home cosy. If by any chance you happen to have a wood fired heater too.... just wait for some logs to turn to glowing charcoal, and you can heat treat or anneal some fairly large objects for free.
2nd Apr 2014, 08:59 PM #10Diamond Member
- Feb 2013
- Laidley, SE Qld
- 1,038
2nd Apr 2014, 10:57 PM #11Diamond Member
- N.W.Tasmania
- 1,407
[QUOTE=bob ward;1762661]Ropetangler, the reducing socket is a transition piece between the air intakes and the 1/2" pipe. LPG in, MIG nozzle and air intake is one piece of steel. The photos are blurry (backgrounds are sharp) but you should be able to see how I made it.
/QUOTE]
Thanks Bob, I think that I have it now, the air control is in 2 pieces (not counting the gas valve and jet assy.) The reducing socket has been machined for a close sliding fit in that inner section, and likewise the outer air control ring I assume.
You didn't comment on the socket on the hot end of the burner, is it just a replaceable end, as in a consumable part and replaced when it gets slowly consumed if used in a furnace, or does it serve another purpose?
RobLast edited by Ropetangler; 3rd Apr 2014 at 09:12 AM. Reason: fix spelling error
3rd Apr 2014, 12:48 AM #12Diamond Member
- Feb 2013
- Laidley, SE Qld
- 1,038
The socket on the flame end as I mentioned is tapered internally and is referred to as a flare. All the reading I've done on these LPG torches suggests that you need a flare to stabilise the flame. I know nothing of the dark arts of flame mechanics so I just go along with conventional wisdom and include a flare.
Flame stability is something to do with the decrease in pressure of the gas flow as it exits from the pipe into the flare into the atmosphere as I understand it.
The flare runs surprisingly cool, I've never seen it become red hot even when running a furnace for an hour at a time, but yes its a readily replaceable consumable if need be.
