Results 1 to 15 of 17
30th Mar 2014, 10:36 PM #1
Older style Angled Parting tool holder ?
Hi , a general question here ,I have been out of the trade for quite some time now, My 20 yr old lathe is a bit worn ,but ok for non critical work My question is I am after one of the older style parting tool holders which were angled similar to the attached picture, they used to take a high tensile holder with a carbide tip braised on , the main advantage is that under load they could give a little ,unlike HSS which can fracture ,especially with a dig in . I have done some searching online but no luck so far ,any body know if these types are still available ,and if so any ideas where ?
My lathe is quite heavy duty but with the old belt drive pulleys and back gear has an 8" chuck and adjustable tapered headstock bearings ,I get a bit of chatter with my current parting tool , and not enough speed for insert tools ,
The ones I remember had a side plate for clamping the tool ,this one pictured is for a back tool post, but the principle is the same I think. Cheers ~ JohnG'day all !Enjoy your stay !!!
31st Mar 2014, 08:26 AM #2Most Valued Member
- 4,258
Like this
A mate of mine who retired from being a toolmaker a few months back gave me some parting insert type blades bit no tool holder. I did do a google and found that they are still available but cant recall where (in OZ to I think)...but being so simple I decided that when I need it I will make one...in the mean time I am going to make a tool holder that willl hold eccentric's parting blades
31st Mar 2014, 08:38 AM #3
Yep ! that's the one , as you say simple and easy to fabricate ,getting some blades may be a problem ,I will keep looking ,there may be a number stamped on the ones you have that may help in that Cheers ~ John
31st Mar 2014, 09:04 AM #4Most Valued Member
- 4,258
Carboloy 1/8 78B
Seco K744.9/S4
Sumitomo KT216 ST20E
Unknown 125 .1
I also have have a Kennewell somewhere but cant find it
Hope the above helps
31st Mar 2014, 09:30 AM #5
31st Mar 2014, 10:04 AM #6Most Valued Member
31st Mar 2014, 10:44 AM #7
31st Mar 2014, 03:58 PM #8
Update thanks for the responses , Blackwoods wanted $40 each for theirs and had no stock in any case , I rang my old boss and he made a few suggestions and the upshot is I now have 2 blades from Carmet here in Brisbane for $50 ,no holder as they wanted $150 for theirs, highly over engineered I feel hehe, so I will go the fabrication route , cheers ~ John
31st Mar 2014, 05:21 PM #9Golden Member
- Jun 2004
- Kyabram. Vic
- 632
You're a bit late, there was about 10 of them on ebay about a month ago. $15.00 posted. A bargain. Quite nice condition as well. Tipped tool in mine was good too.
Ken
31st Mar 2014, 05:24 PM #10Golden Member
- Jun 2004
- Kyabram. Vic
- 632
Ewan,
I see that you are checking this post. Did you miss this lot????
K
31st Mar 2014, 06:29 PM #111915 17"x50" LeBlond heavy duty Lathe, 24" Queen city shaper, 1970's G Vernier FV.3.TO Universal Mill, 1958 Blohm HFS 6 surface grinder, 1942 Rivett 715 Lathe, 14"x40" Antrac Lathe, Startrite H225 Bandsaw, 1949 Hercus Camelback Drill press, 1947 Holbrook C10 Lathe.
31st Mar 2014, 09:11 PM #12Senior Member
- Jan 2009
- Captains Flat
- 122
Is this the ticket?
This looks like what you are after. If so, is free to good home. If interested, PM me.
David
31st Mar 2014, 09:20 PM #13
PM sent Thanks David
1st Apr 2014, 07:39 PM #14Most Valued Member
- Oct 2010
- melbourne, laverton
- 1,910
2nd Apr 2014, 03:29 PM #15Mechanical Butcher
- Oct 2004
- Southern Highlands NSW
- 1,898
I don't see the advantage of this type of parting tool holder, if using a brazed tip with it.
When using a HSS blade that is tapered top to bottom, it does have the advantage that the mounting angle translates that to also provide some side clearance.
That is, it effectively has a reducing width from front to back.
The shape and size of the ground curve needs to be considered for best action, but at least it's easier than grinding tapered side clearances.
But, a brazed tool bit can be a bit wider than the blade, so doesn't need more side clearance.
Am I missing something? Does it have some sort of "gooseneck effect" as well?
Jordan
parting off... or should I say ..how to break the parting off tool
By eskimo in forum METALWORK GENERALReplies: 19Last Post: 19th Mar 2014, 02:29 PM -
Parting tool mounted on rear tool post advice needed
By colbra in forum METALWORK GENERALReplies: 17Last Post: 12th Feb 2012, 02:49 PM -
Has anyone got plans for the reverse parting off tool holder
By bitza500 in forum THE HERCUS AREAReplies: 15Last Post: 15th Oct 2009, 08:51 PM -
Quick Change Parting Tool Holder
By wannabe in forum METALWORK GENERALReplies: 9Last Post: 18th Apr 2009, 10:28 PM
