Results 1 to 9 of 9
    Oct 2011
    Norwood-ish, Adelaide
    59
    6,561
    Default Anyone got a M16x1.5 tap and die?
    I need to make a little adjuster. I could buy the part but it is around the same price as the tap and die to make it. Anyone got a M16x1.5 tap and die (or finer - for the imperialists , 5/8", 17tpi or finer) that I could borrow for a couple of threads? (Plan B is single point turning a nut and bolt but that is a lot of work for a once every so often use adjuster)
    near Rockhampton
    6,218
    I do, but the irony is, it would probably be cheaper to buy a set from China and have them post it, then for me to post it to you from Qld...
    Oct 2008
    blackburn vic
    297
    Default Tap and Die
    Hi Michael
    I have both tap and die for 5/8 UNEF if that is any use.
    Roger
    Jan 2011
    Far West Wimmera
    63
    4,049
    I have an M 16 tap, maybe a die and 5/8 whit tap and die for sure. I am not sure at the moment if any are fine enough. Also dies are 2 inch.
    Oct 2011
    59
    6,561
    True, but my limited experience of cheap taps and dies suggest that they don't always cut...
    Quote Originally Posted by rogerbaker View Post
    Hi Michael
    Roger
    Thanks Roger. I've had a couple of other ideas suggested as well so I'll think through and send you a PM. Tapping drill size would be 19/32" or there abouts?
    Jul 2006
    Athelstone, SA 5076
    4,258
    I have a (3 actually)16x1.5 bottom tap.
    have 16x2 also
    but no dies for either
    Jul 2006
    Athelstone, SA 5076
    4,258
    I bought some of the HSS off CTC and so far so good...better than some of the other crap I have.
    Jan 2014
    Portland, Victoria
    24
    I have extra 5/8 UNF taps and dies you can have if you're interested.
    May 2010
    rural s.a.
    120
    Hi Michael, I have a 16 x 1.5 tap but no die. also have 5/8" x 18 UNF taps (taper & plug) & 5/8 UNF die all sharp. you are more than welcome to borrow them I live south of the city & only come to town Wednesdays. happy to put in padded bag & post. If you are still interested please ring on 0406 411 433.
    tinkera (ian)
