Results 1 to 15 of 40
Thread: Lathe Issue Question
20th Mar 2014, 05:13 PM #1Intermediate Member
- Jul 2009
- 45
- 42
I just picked up a new to me, secondhand AL330A lathe. It has something wrong with it when you turn it on. It sounds a bit like the motor has power, you can hear it, but the spindle wont turn in the high gears until you give the chuck a little start with your hand then it will go. In the low speeds it starts, and the mid speeds it slowly starts and winds up to speed. Can anyone diagnose the problem from this description. I'm hoping it's some small electrical issue I can quickly get round.
20th Mar 2014, 05:24 PM #2Most Valued Member
Hi,
Could be a number of things. My lathe does exactly the same thing, I have been living with it for now but it's a PITA especially when you need to use a high speed. Sometimes I have to warm the oil up in a lower gear and then try the higher speeds. While I have not looked at it yet, my peanut brain just assumes that the start cap is faulty. There is no doubt that it could be any number of issues, all relating to the motor, damaged or over heated windings etc but when I'm ready to look at it, I will be checking the start cap first.
Actually, the only flaw with my theory is that it has two start caps, one for forward and one for reverse. Only issue is that it behaves the same in forward AND reverse. Surely both caps can't be faulty at the same time? Sorry, just me thinking aloud!
Check your start capacitors and go from there...... Other people, more electrically minded will no doubt come up with other theories too.
20th Mar 2014, 05:40 PM #3Senior Member
- Jun 2013
- Tasmania
- 257
As mentioned, if it has a start capacitor it could be that.
If it doesn't have a start capacitor it could be the start windings that have burnt out, but the run windings are ok.
Or, if it has a centrifugal switch that switches the windings from start to run once the motor reaches speed then it might be playing up.
20th Mar 2014, 06:37 PM #4Most Valued Member
- Jun 2012
- SA
- 1,649
20th Mar 2014, 06:51 PM #5Philomath in training
is it better when it has warmed up? While I'm a supporter of the starting cap theory (or perhaps the switch), my previous lathe had trouble starting in top speed until it warmed up. I think it was a combination of bearing adjustment and lubricant viscosity.
20th Mar 2014, 07:01 PM #6Most Valued Member
- Oct 2010
- melbourne, laverton
- 1,910
20th Mar 2014, 07:05 PM #7Most Valued Member
Hi Rob, Ah see I don't know everything! I assumed that the two caps were one for forward and the other for reverse! You say they are normally parallel then I'm good with that……... I'm good.
Hi Michael, when I mean I warm it up, I mean it goes from being impossible to start to starting with some help. I replaced the bearings a few years back and took a fair amount of time and effort to make sure they were nicely adjusted. With the gears in "neutral", the spindle with the 3 jaw, spinning it by hand will see it do a couple of revolutions before stopping. The bearings don't even get warm, in fact I may need to re-nip them up a bit. Manufacturer recommends Mobil DTE light but I use ISO 32 hydraulic oil. I'm pretty sure it's the motor.
Haven't been loosing much sleep over it as I have a nice 3 phase motor lined up for a VFD conversion anyway. After a certain other project is finished!
20th Mar 2014, 08:03 PM #8Intermediate Member
- Jul 2009
- 45
- 42
At a glance it all looks fine, belts are in good condition, and tension is right. The spindle is free as well, out of gear and in gear everything feels just normal. I'll set it up tomorrow and change the oil and run it for a bit and see if it clears up, I doubt it will though.
20th Mar 2014, 08:09 PM #9Most Valued Member
- Oct 2010
- 1,910
20th Mar 2014, 08:33 PM #10Intermediate Member
- Jul 2009
- 45
- 42
No, but I can buy or borrow one, my neighbour is a sparky.
20th Mar 2014, 08:58 PM #11
Sounds like mine. Starter capacitor problem for me.
20th Mar 2014, 09:09 PM #12
For my money, either something is mechanically tight, or the motor caps are failing.
As gearing is applied between the motor and spindle, there will always be an overall power loss. If you are gearing down to a lower speed, the torque available at the spindle will increase in proportion to the speed reduction, gearing up to a higher speed and the torque available at the spindle will decrease in proportion to the speed increase. For Oz mains power at 50Hz, the normal motor speeds are either around 1440RPM or around 2850RPM depending on motor winding configuration.
Say you have a 1440RPM motor in your lathe, and you have selected a spindle speed of 280RPM (hyperthetical). This implies a mechanical speed reduction of 5, and a torque increase of 5x. In practice, the drive train will cost some power and torque, so you have an overall torque increase (motor shaft to spindle) of perhaps 4.
Now say you select a spindle speed of 2880RPM (hyperthetical). This implies a mechanical speed increase of 2, and a torque reduction to half motor torque. Again allowing the same mechanical loss factor of 20% lost, 80% transmitted, the practical torque available at the spindle would be around 0.4 time the motor spindle torque.
If there is anything tight in the drive system, motor, intermediate, headstock gearbox, or spindle bearings, feed gearbox and leadscrew bearings etc when not isolated from the spindle, overtight belts etc, it will have a far greater effect when high speeds are selected than when low speeds are selected.
Single phase motors need a start winding and a run winding to operate. The start windings operate in series with a capacitor to force a magnetic phase shift in the motor windings to establish sufficient torque to start the motor, and to determine the direction of rotation. The start winding carries significantly more (4-6x) current than the run winding, but is generally switched out of circuit with a centrifugal switch once the motor attains about 70 to 80% of its nominal speed so the higher current normally flows for a second or so only. For motors over typically 2HP, a second unswitched capacitor is often used with the start winding, allowing a much smaller current (about .5x run winding current) to flow through the start winding whenever the motor is energised. The run capacitor and start winding causes a magnetic phase shift in the windings, enhancing motor torque and hence power.
If either the run or start capacitors are deteriorating, the motor start and operating torque deteriorate, causing the motor to have poor starting performance, or to fail to start unless given external assistance as the OP has to do to start the motor with higher spindle speeds selected. If there are excessive transmission losses in the drive system, there can be starting difficulties even if the capacitors are functioning properly, due to the excessive load placed on the motor. Continuing to operate in this manner will accelerate the ageing of the capacitors as they become overloaded.
For motor reversing, the same general configuration and components are used (i.e. there is not one cap for starting in one direction and another for starting in the opposite), but the relative phase of the connections to the start and run winding networks is swapped the magnetic phase shift caused by the start winding is in the opposite direction, causing the motor rotate in the opposite direction.I used to be an engineer, I'm not an engineer any more, but on the really good days I can remember when I was.
20th Mar 2014, 09:09 PM #13Most Valued Member
- Oct 2010
- 1,910
20th Mar 2014, 09:25 PM #14Most Valued Member
- Oct 2010
- 1,910
21st Mar 2014, 08:43 AM #15Most Valued Member
- 4,258
as said above it sounds electrical....I'd be checking the electrical side first to make sure all is okay there
eg capacitor, Motor windings, Centrifugal switch if it has one, wiring continuity capacitor/motor etc etc
vfd question for my lathe motor
By tanii51 in forum METALWORK GENERALReplies: 5Last Post: 27th Jul 2011, 09:40 PM -
lathe thread question
By turbo TA in forum METALWORK GENERALReplies: 14Last Post: 28th Aug 2009, 10:06 AM -
Lathe question
By lubbing5cherubs in forum METALWORK GENERALReplies: 3Last Post: 30th Aug 2007, 11:02 PM
