Results 31 to 40 of 40
Thread: Lathe Issue Question
23rd Mar 2014, 04:37 PM #31Intermediate Member
- Jul 2009
- 45
- 42
Might be a dumb question, but there is a large one and a small one on the motor, which is likely to be the start capacitor?
23rd Mar 2014, 09:15 PM #32
The larger one is likely to be the starting capacitor....
Bu please check their labels. The one with highest uF number is the starter one. I may have a lower voltage rating than the run capacitor.Cheers, Joe
23rd Mar 2014, 09:23 PM #33
The caps should be labelled with two values, the capacitance in microFarads (uF), and the voltage rating (VAC).
The cap with the greatest capacitance value will be the start capacitor, and would be the physically larger capacitor provided that both have the same voltage rating.
If you are looking to replace either, you need the same capacitance as the originals, and a voltage rating the same as, or higher (never lower) than the originals. However higher voltage may be physically larger and might not fit in the original location/housing.
If the motor is cap start/cap run as you are saying, I would try to source and replace both in one instance if possible, unless you are very close to a supplier, or can afford the time for repeat trips etc.I used to be an engineer, I'm not an engineer any more, but on the really good days I can remember when I was.
23rd Mar 2014, 09:25 PM #34Intermediate Member
- Jul 2009
- 45
- 42
I Just removed the covers and had a look, and visually they both look fine.
The spindle has light tension, just like similar models I have had in the past, and it runs fine. To check the bearings I left it running for an hour or so at 540 RPM and the spindle had only got slightly warm, there's no noise and it cuts smooth and accurate. So I don't think I have a mechanical issue.
Should I just order the new starter cap and give it a run? The motor has power when it should, so I guess everything else should support function. Is there any way to test the existing capacitor? Or any point?
23rd Mar 2014, 09:32 PM #35Most Valued Member
Hi Malb,
One is Fwd, one is Rev, the other is part of the "controls". It closes when the power is turned on(or the e/stop is removed) but only if the fwd/off/rev lever is Off. Its there so the machine won't restart if the lever is left in the on or rev positions after either lose of power or the E/stop has been used.
At least thats how it is on my lathe
23rd Mar 2014, 09:59 PM #36Intermediate Member
- Jul 2009
- 45
- 42
Thanks guys, I'll order these components and replace them when they arrive. Thanks a lot for the advise, it is greatly appreciated and I'll let you know how it goes.
Tom
24th Mar 2014, 08:47 AM #37Most Valued Member
- 4,255
25th Mar 2014, 06:47 PM #38Intermediate Member
- Jul 2009
- 45
- 42
All Sorted
Thanks for the help. I ordered the start and the run capacitors from Hare and Forbes yesterday, they showed up today, and I put them in. All sorted, problem solved, and the machine runs like new.
As I mentioned I levelled it and got it setup and the alignment is excellent and I don't expect any dramas from here. Did a couple of little jobs on it last night and I'm really pleased.
25th Mar 2014, 11:07 PM #39Diamond Member
- Sep 2006
- Australind , WA
- 58
- 1,277
26th Mar 2014, 12:25 AM #40Most Valued Member
vfd question for my lathe motor
By tanii51 in forum METALWORK GENERALReplies: 5Last Post: 27th Jul 2011, 09:40 PM -
lathe thread question
By turbo TA in forum METALWORK GENERALReplies: 14Last Post: 28th Aug 2009, 10:06 AM -
Lathe question
By lubbing5cherubs in forum METALWORK GENERALReplies: 3Last Post: 30th Aug 2007, 11:02 PM
