Results 16 to 24 of 24
Thread: Ideas for making a motor fan
24th Mar 2014, 12:50 PM #16Most Valued Member
- 4,258
24th Mar 2014, 01:32 PM #17Member: Blue and white apron brigade
Sure - yes no load. I've been using "no load temps" to identify problems like sticky bearings etc. On one motor, the shaft temp got up to ~50º just free running. after a lot of mucking about I identified this with a poorly assembled motor where one bearing was not seating properly into its end cap so the thrust spring under the other bearing was probably totally crushed. A few from taps of a wooden mailet seated the tight bearing and reduced the pressure on the thrust spring and the shaft temp dropped by ~20º
25th Mar 2014, 08:27 AM #18Most Valued Member
- 4,258
25th Mar 2014, 11:30 PM #19New Member
- Feb 2014
- Australia
- 7
I would go for the external fan; you can get some good prices if you look for used pieces
26th Mar 2014, 12:14 AM #20Member: Blue and white apron brigade
27th Mar 2014, 08:23 PM #21Member: Blue and white apron brigade
Paul McGee like pictures so here is one of a small (0.25 HP Y connection 415V) motor that I found in a skip big where I used to work.
It meggered OK and gave consistent coil readings so I thought I would use it as a practice run for Y to 240 ∆ conversion.
The internal insulation was strong but brittle and I ended up prying/shattering/chewing open 4 connections before finding the common point.
There was plenty of room inside for the extra wiring and I covered all the opened connections up with fibreglass sleeves and smothered it in HT silicone and it came together easily enough.
It had some corrosion on the main motor case and the aluminium fan casing so I ran a wire wheel over it and gave it my standard motor paint colour treatment.
This is a nice little motor, It seems to have a bit more grunt than 1/4HP but without a dyno I'll not really know - yet another reason to make one.
What am I going to use it for, nothing yet, It's going back into my motor stash till I find a need for it, I have another just like it that also could used some TLC
28th Mar 2014, 01:19 AM #22
I find it a little interesting that there is a 1/4hp 3phase motor ... not astonished, just interested.
I assume it isn't 3ph over 1ph for current-draw, so ... torque? reliability? keeping loads balanced on a 3ph wiring system?
Just curious.
When I asked about a picture, I was imagining 3ph like this ... ...
Paul
28th Mar 2014, 06:45 AM #23Philomath in training
Could be a smaller part of a larger 3 phase machine so it is done for balance. Another possibility is that 3 phase motors are smoother than single phase and don't need a separate starting mechanism, so if used intermittently that could be a reason too.
28th Mar 2014, 09:43 AM #24Member: Blue and white apron brigade
Ideas for making one of these:
By Sterob in forum METALWORK GENERALReplies: 21Last Post: 26th Sep 2013, 09:45 PM
