Results 1 to 15 of 25
Thread: Hobby Metal lathe
12th Mar 2014, 09:48 PM #1
Hobby Metal lathe
Hi All,
I'm new in here and need some advice (maybe plenty of it) regarding a metal lathe. I will be using it to construct small parts for model planes/trains/trucks etc. I am so confused with what's out there. I would possibly need say maybe 300mm between centers.
Any help and ideas in the matter would be greatly appreciated..
Thanks and best to all
bosco
12th Mar 2014, 09:57 PM #2
Welcome Bosco,
You are more than likely to find someone here with similar interests to your own.I can't advise on much save to say that your machine if new should come from a dealer with a good reputation,spare parts back up and a good warranty.
Be prepared to spend a good deal extra on the tooling as everything you will need to get started won't necessarily be provided with your new machine.
13th Mar 2014, 06:46 AM #3Philomath in training
- 6,540
Can we have a little more information please?
Things like -
- Will you want to cut threads
- What materials are you intending to use (Steel/ brass/ plastic/ stainless/ aluminium/ etc)
- What sort of maximum diameter that most of your parts would fit into
- Is this for occasional use or do you think that it will be in use at least weekly
- When you talk of parts for models are you making working models or static models
- Do you want to make parts from scratch or are you mainly intending to modify existing parts (for example, shorten bolts or polish shafts)
Don't worry if you can't answer all these questions. A good guess is fine. It's just that as you have noticed there is a variety out there and it's the features available that sort then apart. The Sieg range is usually considered reasonable but you may find if you want to cut threads for example you have to go to a larger machine than you anticipate because the smaller lathes are not set up for that.
I have a theory that says every lathe owner will own at least one lathe; one to learn what they really want and subsequent lathes to try and get it, so don't be surprised if you answer some of these questions one way and then find later on that you are not using it that way.
13th Mar 2014, 11:40 AM #4
13th Mar 2014, 11:52 AM #5
260
i WOULD GO FOR A hERCUS 260
Lots of replacement parts around and they are a excellent machine .... Mike
13th Mar 2014, 12:17 PM #6
I would look for a good secondhand lathe with at least a 38mm spindle bore, nothing worse than having to keep cutting stock because you only have a 20mm spindle bore. The larger spindle bore will also have an MT4 or MT5 taper as well.
Shane
Got the square peg in the round hole, now can't get it out !!
13th Mar 2014, 02:20 PM #7
Hi All,
Sorry to be a pest, I'm in Perth..where can I source one of these Hercus lathes?
thanks
13th Mar 2014, 03:43 PM #8
Hi Bosco,
Quite a lot of Hercus machines were sold to the high school system and some tech colleges.'
Some schools may still have them it is may be worthwhile checking to see if your local schools have one and are intending to dispose of it.
13th Mar 2014, 03:47 PM #9Member: Blue and white apron brigade
- 7,182
I think this is a bit over the top for someone who wants to "construct small parts for model planes/trains/trucks"
RE: Sourcing a 260.
They are all second hand at this stage.gumtree.
eg
http://www.gumtree.com.au/s-ad/banjup/other-tools-diy/lathe-hercus/1041055704
PM me if you want to come and see a Hercus and discuss what it can and cannot do - Mines not a 260 but it will still be similar.
13th Mar 2014, 04:32 PM #10Shane
13th Mar 2014, 04:47 PM #11
If you do decide on a hercus, put a wanted add on gumtree. As I have just found out you never know what may turn up.
I would also take Bob up on his offer. Have a look, note the quality and feel. Then go and have a look at a seig or other Chinese machine, the differences in quality are huge.
13th Mar 2014, 05:33 PM #12
I'm thinking that 30mm would be a bit too large for what I intend to do...mostly dealing with stuff in 1/48th 1/35th 1/32nd scales. If I think about it, 30mm is the size of a sideshaft on my jeep just about...
Was thinking something like this:
http://www.ebay.com.au/itm/12-x7-300...-/390791372090
What do you guys think?
thanks again
13th Mar 2014, 05:36 PM #13Most Valued Member
- Australia east coast
- 2,713
I'd rather have a Chinese lathe with a decent spindle bore. RC & I have both owned Hercus lathes. I don't any more and I'm pretty sure he sold his too.
Questions come down to, how deep are your pockets and how long are you prepared to wait before getting a machine? Good quality used machines come along reasonably frequently but you have to be prepared to move fast.
PDW
13th Mar 2014, 05:44 PM #14
Hi PDW...I cannot justify spending thousands, not for what I want to do...I have spent big $$$ on a woodfast wood lathe, and nearly got served divorce papers...for static models, you know...chinese would be OK...unfortunately in Perth (to my knowledge), there isn't much of a variety/showrooms where one could go and drool or test and see what could be good for one's purposes...bugga!!
13th Mar 2014, 05:57 PM #15
So would i, for sure. But I don't think that's what bosco wants. I looked at at hercus locally for someone else, I was amazed at just how small they actually are. My mars is considerably heavier and I think of it as floppy these days. But then the ability to take 3mm doc's with carbide aren't what everyone needs or wants.
Knurler for small hobby lathe
By Jim Ferrous in forum METALWORK GENERALReplies: 21Last Post: 16th Nov 2013, 08:56 PM -
Hobby Metal Supplies
By bigphill in forum METALWORK GENERALReplies: 5Last Post: 21st Sep 2013, 08:04 PM -
Antique Drummond hobby lathe
By morrisman in forum METALWORK GENERALReplies: 7Last Post: 11th Jan 2012, 11:31 AM -
Choice of hobby lathe
By Terry B in forum METALWORK GENERALReplies: 6Last Post: 23rd May 2010, 10:59 PM
