Results 1 to 4 of 4
3rd Mar 2014, 07:08 AM #1Senior Member
- Salem Ohio
- 219
Treadmill motor swap flywheel reworked.
Made an adapter to bolt to the cast iron flywheel to adapt a larger motor where the orig was threaded on. Made up a hub with a flange and cut the ribs from the flywheel to fit. Then bolted it all together then added the bore and keyway...Bob
3rd Mar 2014, 07:37 AM #2Mechanical Butcher
- Oct 2004
- Southern Highlands NSW
- 1,898
Neat job.
Did you bore all the way through to the pulley side? Or did you have to match up to the existing bore? (which must have been tricky, if you did).
Jordan
3rd Mar 2014, 08:16 AM #3Senior Member
- Salem Ohio
- 219
Yes i had to bore all the way through it because of the keyway i added. It was a 3/8" threaded hole orig for the first motor which the shaft was threaded. I indicated off the OD of the flywheel in my 8" 4 jaw chuck and cut the ribs for the hub which i made in another chuck first. It should work real well for the guy who isn't a metalworker but he found me online. This was my second one as i did an aluminum one a year ago pretty much the same way. He wanted a new hub welded to the flywheel which i didn't want to weld on it but i could have...Bob
3rd Mar 2014, 09:35 PM #4Diamond Member
- N.W.Tasmania
- 1,407
Your usual nice work Bob, thanks for showing it off.
Rob.
