Results 1 to 15 of 21
10th Feb 2014, 11:07 PM #1.
- 6,459
Waldown Intermediate Pulley Eccentric Mount Photos
Waldown call the mount an intermediate drive block ( part no 104419 ).
Joe asked for a few photos of the pulley mount that I have on my 3M and my garden shed beater drill so here's the 3M's. Might be of use to someone else. Who knows
11th Feb 2014, 04:20 PM #2Most Valued Member
Bob, thanks for the pics, if I need something like that I'll now know how to do it.
11th Feb 2014, 06:01 PM #3.
- 6,459
11th Feb 2014, 07:11 PM #4
Thanks a lot Bob! I got them by your e-mail as well.
That is how I imagined it would look - glad I wasn't way off track. Just have to figure out the bearing arrangement and my pulley. The locking mechanism is nothing like I would have thought.
Cheers!Cheers, Joe
11th Feb 2014, 09:57 PM #5Distracted Member
- May 2010
- Lower Lakes SA
- 58
- 2,607
Yes thanks for the pics Bob. I've never managed to get mine apart. What engages the large groove in the bottom of the eccentric? Presumably that is what retains the assembly.
11th Feb 2014, 10:23 PM #6
The two motor mount pins run through the bore for the column. The groove both accommodates them and provides a positive stop for the eccentric. It means the motor mount has to be pulled almost completely out of the drill body to get the eccentric out. Quite clever I think...
Cheers, Joe
12th Feb 2014, 08:31 AM #7Distracted Member
- May 2010
- Lower Lakes SA
- 58
- 2,607
Diabolical. Thanks Joe.
12th Feb 2014, 04:54 PM #8
Looks like my home-made version will require a revision because my designated intermediate pulley doesn't have enough 'meat' in the casting to accommodate any bearings. I will need to fit the bearings into the eccenter part and have the spindle run with the pulley attached. I have an idea I can make that work.
Cheers, Joe
12th Feb 2014, 05:43 PM #9.
- 6,459
30th Apr 2014, 10:27 AM #10Most Valued Member
- 4,258
Hi Bob
Let me get this right...
the intermediate drive block just sits in the column?
what is purpose of brass pin (drive plunger) and the drive handle?
30th Apr 2014, 10:35 AM #11.
- 6,459
Hello Richard,
Yes, the eccentric block sits in the column and the handle with it's brass plug simply locks the block in position. You might be thinking that the belts would position the pulley and the eccentric but the handle enables the tensioning of the spindle belt with subsequent locking after which the motor belt can be tensioned.
Bob.Last edited by Anorak Bob; 30th Apr 2014 at 10:44 AM. Reason: Thought it good to answer both questions!
30th Apr 2014, 10:44 AM #12Most Valued Member
- 4,258
30th Apr 2014, 04:32 PM #13Most Valued Member
- 4,258
Joe
I see that you made an intermediate pulley for your 8sn
the column on mine appears to have an internal seam. Did yours?, and did you do anything to compensate or bore the column?.
or shouldnt I worry about an intermediate?
30th Apr 2014, 04:50 PM #14Most Valued Member
- 4,258
Hi Joe...I'll start again...the column doesnt go all the way up duh...
Did you just knock out the steel cap and just drop the block into the casting as the 3m series?...or did you do something different?
30th Apr 2014, 06:48 PM #15Philomath in training
