Results 16 to 19 of 19
7th Feb 2014, 01:26 PM #16Intermediate Member
- Nov 2006
- kansas mostly
- 33
As a suggestion for anti-scale compound, I've heard of folks using borax (here in the States, 20 mule team brand) mixed with alcohol. Brush it on and let is dry. I don't know how well it works as I've never used it.
Warm oil cools faster than cold oil so pre-heat your quenching oil to "warm to the touch".
ron
7th Feb 2014, 02:34 PM #17
Ron & Andrew
I use borax when making small jewellers tools.
It works VERY well.
Here is a 12mm long piece of 6mm round silver steel I quickly cut and played with.
Warmed it up and dipped half of it in powdered borax which melts onto the surface into a paste. Then held it in tweezers above a glass of water and heated it to cherry red and dropped it from about 50mm to the water.
The black scaling is eaten into the surface, and the protected area has not been "etched". The mottled look on the bright side is just a stain on the surface.
I've used this process for about 35 years to save time stoning away the scale that would otherwise be on my engraving and diamond setting tools after hardening them before tempering.
I would suggest you put each of the small pieces on a steel wire and warm them up, cover them with molten borax by heating them up and immersing them in the borax powder over and over until a good even coating is on them. Then do the heating up to red.....etc.
Regards,
Peter
7th Feb 2014, 07:14 PM #18
Hi Peter, Very nice,
I must give that a try... I think the Rosemill PBC stuff I've got is most like borax based, they sell a range of other borax based materials... PBC Anti-Scaling Compound
9th Feb 2014, 03:37 PM #19Chief Swarf Maker
- Aug 2013
- 132
Thanks for all the replies guys. Unfortunately i messed up my estimations on piston-to-valve clearance, the stock pistons wont clear the 2mm OS valves at my compression height :s
So the head isnt going on this weekend.
I will pull the (nearly new) bottom end out/apart, and either relieve the cast pistons on the CNC, or fit the forged flat tops ive got stashed away (which were made to suit huge valves and cost the GDP of a small nation). 14:1CR in a road car... why not?
Either way this buys me enough time to get the shims hardened professionally, which ill feel much more confident about. Thanks again for all the help and suggestions.
Case Hardening Steel
By .RC. in forum METALWORK GENERALReplies: 17Last Post: 10th Nov 2012, 09:46 AM -
stainless steel grade for hardening
By thorens in forum METALWORK GENERALReplies: 6Last Post: 6th Apr 2012, 11:23 AM -
Silver Steel
By YarrD in forum METALWORK GENERALReplies: 9Last Post: 20th Oct 2011, 09:38 AM -
Case hardening steel in the workshop
By .RC. in forum METALWORK GENERALReplies: 0Last Post: 10th Apr 2009, 10:01 PM
