Results 1 to 8 of 8
3rd Feb 2014, 06:59 PM #1Member
- Feb 2012
- 61
Help needed. I need to find an engineer
G'day guys, as the title says, I need to find someone to do some work for me.
I am currently working on a small hobby grade cnc. The plans call for 20mm presision ground shaft with an M8 hole tapped in each end and some trapezoidal screws with turned ends also.
I have contacted a few enginneering companies but none are being all too responsive.
I will include a pic of the work I need done. Can anyone do this? Im am located in western sydney.
Thanks in advance guys
Shane
Sent from my GT-I9507 using Tapatalk
3rd Feb 2014, 10:33 PM #2Most Valued Member
- 4,890
Is there any tolerance on the length of leadscrew?
Are you supplying material?
Have you tried to cost this?
Are you on a limited budget?
3rd Feb 2014, 11:08 PM #3
You can get pretty much what you are looking for as far as materials go, on the various ebay cnc suppliers.
20 mm ground shaft http://ww.ebay.com.au/itm/SF20-400mm...item461781e85c
14MM acme lead screw TR14X3DX400MM Trapezoidal Acme Ballscrew Leadscrew CNC | eBay
Have you considered ballscrews rather than acme?
3rd Feb 2014, 11:52 PM #4Member
- Feb 2012
- 61
4th Feb 2014, 12:57 PM #5Senior Member
- Sep 2009
- Newcastle
- 342
Acme / trapezoidal is a bit hard to find in Australia in my experience. There is only limited stuff available.
What plans are you using?
4th Feb 2014, 01:12 PM #6Golden Member
- home
- 621
The previously quoted eBay seller also has ACME threaded rod in 12,16 and 22mm, no 14mm
There's still the machining requirement though.
TRPZ16X4 800mm Trapezoidal Screw Acme Lead CNC Router Motion Thread NUT Machine | eBayGeoff
The view from home
4th Feb 2014, 03:44 PM #7Golden Member
- Apr 2009
- Kingswood
- 930
T.E.A. Transmissions in Brisbane stock various sizes of threaded rod specified for machine leadscrews in quite long lengths.
They can machine ends to requirements.
Engineering trade components supplier - Special purpose engineering products - TEA Transmissions Australia
John.
4th Feb 2014, 06:27 PM #8Member
- Feb 2012
- 61
